- Maurizio
Hmm thinking about the matter, it is pretty complex to get a feel for forces on the spindle.
If we take the outside wheel there are 2 forces working:
- the rim is pullling due to the corner speed and adhesion.
- and the spindle is bend to the other side, due to the weight transfer on the outside wheel and perhaps some extra braking.
The vertical load is not very relevant and it counteracts the real force coming from cornering. The ET as well as camber do not matter. They do in street driving where you drive for miles in more or less straight line.
The important "force" is coming from cornering and acts on the axle with ~ lateral acceleration * front axle mass * tire radius or about 2-2.5 kNm in this case.
I agree the main thing is wheel radius and max instantaneous g's (or steady state g for a constant radius/speed turn)and the front axle portion of the pig's weight. Camber shouldn't make a difference and neither should offset (within the realistic values we deal with). And then, with stickier tires you can have more speed = higher g....
While we wait for the coroner's report, I'm looking for thicker spindles...not easy to come by!
With a bigger spindle, won't you need a whole slew of new things? The bearings will have to be smaller or the hub needs to be bored out. Now since you discovered that even the spindle can flex, how will milling the hub affect the strength of the hub?
BTW Jim, did the 75 1.8T racers have bigger spindles?
Alfa Six sedan had GIANT spindles..
I do know that the early GTV Strada coupe had baby spindles -the GTV6 went bigger...
I still reckon theres some thing else here..I have never come across this before.
Untill I do,Im really not worrying myself about it here...Jim,I have hit a curb side on and rolled cars and the spindles have not bent..the upright was pretty fk`d..but the hub and spindle were good..
Your hubs where the bearings locate aren't worn perhaps??
Everything is new Barry (well, 4 months old!)
Zamani, bigger spindles come with bigger bearings and hubs...for once AR knew what they were doing but quickly decided to save some metal on subsequent cars Yes, racing 1.8T's had special spindles (alloy+steel) seen somewhere in the site a while ago and the Evo had the big ones Barry mentioned.
The evo had bigger ones? Maybe I should take a drive down to the garage and measure on the ~10 different 116 cars standing there including 75 t and 75 Evo.
Ok,I graciously bow out from the topic...
- Maurizio
I agree for the fast math take the G's, corner weight and outside wheel diamter.The vertical load is not very relevant and it counteracts the real force coming from cornering.
So for a fast calculation I need some dimensions.
Distance between rotation point upper and lower balll joint.
Distance rotation point lower bj to axle centre.
Minimal cross section spinde.
Axle: distance between bearings and cross section axle.
Micke did use a g meter on the ring in my car and also did the same with Ron's demo car. I remember Ron doing a consistant 1.5 G's in the corners and a 1.6 through carrossel (I was doing 1.3 and 1.5 ). He is running very sticky P zero's. A TS is less front heavy so will do a faster turn but ok as reference for the fast sum.
@Micke Is that 2-2.5 kNm you predicted?
Better spindles, how a bout SZ spindles, will only work when using 16" wheels. The car was claimed to do a 1.1G in standard trim.
Improves your roll centre as a bonus
Have looked for them a long time and they are $$$$$ if you find them.
- scott.venables
Re: Spindle flex under cornering....beware!
Thread revival!
Did you figure something out Jim? At our last club sprint meeting a friend of mine with a 75TS turbo racer was having trouble with the inside of the wheel rim rubbing on the bottom ball joint stud. I've made up these for him to try out at the next meeting. They're threaded with a 1mm pitch to set the wheel bearing play. Any comments from the engineers?
If it works I might do a run of them.
Scott
Scott
- SpindleBearingSpacer.JPG (67.45 KiB) Viewed 8454 times
were the 75/gtv6 spindle units all cast at the same facility?
- Maurizio
I guess this bush is placed between the two inner bearing rings...They're threaded with a 1mm pitch to set the wheel bearing play.
But how do you set the wheel bearing play. Dismantle the hub several times?
- scott.venables
Basically. You could install it too long, then measure the play with a dial gauge and shorten the spacer accordingly. That would be quicker.Maurizio wrote:I guess this bush is placed between the two inner bearing rings...They're threaded with a 1mm pitch to set the wheel bearing play.
The upright is forged then machined and the spindles are machined and then pressed/welded in. But I'm not sure where they all came from.xrad wrote:were the 75/gtv6 spindle units all cast at the same facility?
Scott
Scott,
In this set up, how is the steering arm fitted to the whole assembly? Would it be possible to position it in a different arc location to cater for bump steer adjustment at the same time ?
- scott.venables
Hi MD. This fits standard 75 upright/spindle, this is a spacer that gets clamped between the inner races when the nut on the end of the spindle is tightened.
The first car they will be fitted to has lengthened uprights with bent steering arms for bump correction.
Scott
Scott
