Author Message
<  Braking  ~  Braking issues: Locked brakes.
PostPosted: Fri Jun 01, 2007 2:05 am
User avatarSilverSilverJoined: Wed Dec 08, 2004 12:03 pmPosts: 30Location: Oude Pekela, the Netherlands
Hi fellow transaxlelovers,
I got myself a problem here.
I keep getting locked brakes at the rear, even without intensive use as on the race-track.
I'm using the GTV6 all the time till winter starts.
It occured monday on the paddock of the dutch TT- race-track in Assen.
Just as i was about to go on the track to make some laptimes.
It also happened some times before that, just looks like it's getting worse every time.
Quite frankly it's starting to piss me off...
Now my question is, what could be wrong with them?
Regards, Arjan.
PS. My apologies if i'm not to clear with explaining it in english. :oops:
_________________
GTV6 DRIVES YOU 2 PASSION!
http://www.gtv6demoruns.nl/
Offline Profile
PostPosted: Fri Jun 01, 2007 11:00 pm
User avatarVerdeVerdeJoined: Fri Jun 02, 2006 7:45 amPosts: 535Location: portland, oregon, USA
sounds like it might be time to re-build them as theres either rusty or gummy build up causeing them to stick
Offline Profile
PostPosted: Sat Jun 02, 2007 12:26 am
User avatarVerdeVerdeJoined: Sun Dec 05, 2004 11:33 pmPosts: 810Location: Finland
Rear pressure limiter stuck????
Offline Profile
PostPosted: Sat Jun 02, 2007 4:13 pm
VerdeVerdeJoined: Tue Jun 13, 2006 9:47 pmPosts: 765Location: Fresno, Ca.
Bad flex hose maybe?
hth,
Scott
Offline Profile
PostPosted: Sun Jun 03, 2007 7:06 am
At least i've got some leads now what could be the cause.
Both from here as the dutch Alfetta-register.
Thnx.
Shamefully i can't check it myself, don't have a descent garage where i can make repairs.
So i'll have to ask someone to check it for me. :roll:
_________________
Offline Profile
Display posts from previous:  Sort by:
Page 1 of 1
Users browsing this forum: No registered users and 1 guest
Search for:
Post new topic  Reply to topic
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
cron
