The ones I have are the Dynalite II Billets. Yuo can get the Dynalite II forged for US$110. Caliper piston size I used with 24mm MC (from a 164) is 1.38"..Jose_76 wrote:Zamani, could you tell me what part number/reference are the Willwood Dynalite calipers? What diameter are those Supra rotors?
Supra rotors came from the '86-'91 model with the 7MGE (MA80 chassis?). 302mm X 22mm, and I think 52mm hat height.
You could try the one from the latest model (JZA80 chassis, 2JZGE engine) but the hat height may be different. The 2JZGTE equipped Supras (TwinTurbo) will obviously have thicker rotors, which will probably suck BHP since it is heavier.
So, Zamani, the ones that fit the car are the showed here:
http://www.wilwood.org/catalogs/tech/ca ... aliper.pdf
as Part Number: 120-5093, Right?
Can these calipers and Supra rotors be fitted with the stock 15" rims?
'84 Red GTV6 3.0
they fit the gtv6 , but; with a specially designed mounting bracket....!
looks like that near 298-305mm seem to be the maximum size to enter on any kind of 15" wheel.
but this should be checked for each wheel.
i know that the dynalite fit on gtv6 oem 15" wheels with 298mm(11.75") disc.(0.81" discs and small plate beetwen hub and wheel)
2 stroke addict
Amazing amount of info found on the old forum.
Here's just a few of many threads regarding big brake conversions:
Contains Barry's & Daniel's brake conversion
http://www.alfagtv6.com/discus/messages/205/4279.html?
Marcel's, Mat's and Zamani's upgrades:
http://www.alfagtv6.com/discus/messages/205/1601.html?
Marcel's discussion on upgrades
http://www.alfagtv6.com/discus/messages/205/541.html?
So, what was the problem? It is always very interesting to know a bit more than just hearsay? I know about AP-brakes that work just fine, but also some that did not work too well.rz wrote:from all the tarox brake conversions i heard they were not working great(on the alfa sz or rz's)
ap racing worked fine!
were are you from zagato??and what car do you have?
Normally the problems come from using the wrong components for a specific use.
So I know that there is TAR-OX kits that does work very well, but there can also be some that does not work so well.
By the way I have more than one car, but all ALFAS!
