aftermarket masters?
sh0rtlife
Post by sh0rtlife » Wed Apr 02, 2008 10:48 pm
ok guys ive got stock clutch slave and stock milano front and rear brakes...the problem is..my project REQUIRES after market pedals and box..im going to run a reverse swing setup EG the masters are INSIDE the car above your feet
what i need to know is what size of masters should i run?..the setup i snagged off ebay came with 3 7/8's masters(1 front 1 rear 1 clutch).....i wasnt happy with the "stock" master on my gtv6 but am fairly pleased with the 24mm pulled from a BMW
any input or links to figure this info out would help me greatly
the setup i picked up is an old howe...same as coleman, afco, tilton, willwood, us-brake...same masters too
Post by Mats » Thu Apr 03, 2008 12:07 am
The size of the MCs depend on a shitload of factors including Center of Gravity Height, Tires, size of brake discs, size of pistons in calipers, pad compound, desired feel in pedal and so on and so forth...
Not so simple...
Post by MR2 Zig » Thu Apr 03, 2008 5:26 am
check wilwood's web site I THINK they have a section on master cyl selection.
sh0rtlife
Post by sh0rtlife » Thu Apr 03, 2008 11:30 am
ahh hell i didnt think it would be that hard...i want a close feel to the 24mm bmw swap setup...lets asume for now everything else is the same as stock just 1000lbs lighter
AlfaTipo
Post by AlfaTipo » Thu Apr 03, 2008 1:35 pm
Mats is right. Pedal ratio as well. No booster?
Jef
www.motozane.com
AlfaTipo
Post by AlfaTipo » Thu Apr 03, 2008 2:24 pm
Jef
www.motozane.com
sh0rtlife
Post by sh0rtlife » Thu Apr 03, 2008 9:18 pm
nope NO booster.....not sure about pedal ratio just yet as well...ive not built new pedals yet...anyway to tell what rato the pedals are?..ive got the old setup which are well..TRASHED but my pedals will be the same length
AlfaTipo
Post by AlfaTipo » Sat Apr 05, 2008 10:21 am
Pedal ratio is the distance from the pivot point to the booster/mc link compared to the pivot point to the pedal.
Jef
www.motozane.com
