El cheapo rear vented brake upgrade - ideas?
PietereQ
Post by PietereQ » Tue Feb 07, 2012 2:06 am
Let's state three things:
-outboard brakes are not an option (say regulations)
-SZ/RZ rotots unavailable / extraorbitant prices
-custom stuff; alu floating hats etc etc out of question
I believe someone has tackled with the issue here. I asked some local chaps for some aftermarket rotors with relatively close dimensions to the originals.
So let's start...
Alfa rotor:
Peugeot 405, 306, partner and rest of the PSA gang...
Citroen Xara 1.9TD
Jag S-Type
Uploaded with ImageShack.us
I was thinking of either using stock calipers, or calipers that were working with these rotors.
Any opinions, ideas, suggestions?
Re: El cheapo rear vented brake upgrade - ideas?
Post by kevin » Tue Feb 07, 2012 7:47 am
I had ventilated discs with bells made here and was very reasonable . Compltete was R3000 . Which was 250 euro then . Spacers for for caliper was 40 euro. This matched the sz set up exactly.These disc were cut from a Nissan disc . Not sure which model .
75evo
Post by 75evo » Tue Feb 07, 2012 9:45 am
I seem to recall some kind of pug 106 front vented rotors.
Alternatively, what about spraying cool mist on the rear brakes? Maybe air scoops from the top or bottom of the car with the cooling mist spray. With garbage dot3 fluid, my brakes now all vented, had not much of a overheating problem. So the rear vented brakes do work. But if the cost is crazy, probably cooling mist and ducting may help. But the fact is, heating up the brakes kills the seals. So even if your brake fluid doesn't boil, eventually you will kill all the seals. I'm going to improve the brake ducting water misting.
killaz
Post by killaz » Sat Mar 03, 2012 2:13 pm
Post by Giuliettaevo2 » Sat Mar 03, 2012 3:23 pm
www.brembo.com has an aftermarket list of discs online. You can search on different things like centre hole diameter, thickness and overall diameter. :)
PietereQ
Post by PietereQ » Sat Mar 17, 2012 4:10 am
Wow those kia rotors look quite promising yet i guess the centering hole and pcd are wayy to big. Anyway, I have comepetely taken apart the dreaded rear calipers, and looking at their internals there is NO WAY you could compeletely bleed them in normal conditions... we already know that 105 series rear caliper is a bolt on upgrade without the silly handbrake mechanism, but good luck finding these easily. Then I came across Volvo V70 rear calipers which looks like this:
If I only knew the dimensions
Post by MR2 Zig » Sat Mar 17, 2012 4:44 am
A junkyard/breaker/recycler could be your friend... a known bad caliper could be bought on the cheap and used for fitting / checking for size, etc.
Post by Giuliettaevo2 » Sat Mar 17, 2012 3:02 pm
If you're at a breaker, check the rear calippers from an Opel Omega as well... i believe they fit on the gearboxside.
kterkkila
Post by kterkkila » Fri Jun 01, 2012 11:11 am
Mazda B2000 + adapters:
These have been well working setup on my endurance racer for years.
Kimmo / alfatune.fi
