Author Message
<  Braking  ~  Brake Bleeding
PostPosted: Mon Aug 03, 2009 7:03 pm
User avatarSilverSilverJoined: Tue Mar 01, 2005 3:37 pmPosts: 32Location: Melbourne Australia
I had no luck until I made up a pressure bleeder (retail are way too expensive here in Australia). I put a brass nipple on top of a spare master reservoir cap and a tube to a tyre valve connector. I used a bicycle tyre at 12-15 psi. I found I had to use a bit of wood to keep the brake pedal half depressed, or otherwise I drained one half of the master while there was fluid still in the back half! I then started at the rear, one side at a time. I started with the Australian drivers side (right-hand) that has the longer brake line. Open the bleed nipple wide enough to get a good flow of fluid, ½ a turn or more. Had to open the nipples so far that they leak a fair bit from the threads as well.
My theory is that I needed a quick flow of fluid to prevent the air bubbles from floating back up the lines.
What I will do next time is put Teflon on the bleed nipple threads to stop the fluid leaking out there as I was worried I’d get fluid on the disc rotors. Same for the fronts as they had been painted when re-built.
I found that 10psi didn’t work. I seemed to get all the bubbles out, i.e. good clear fluid flow, but still had a soft pedal. Hence 15psi or more and cracking the nipples more than half a turn to get a good rush of fluid! I have read of the 105 guys causing problems with the seals in masters at pressure above that though.
Top up the master and I could probably bleed all four several times without trouble, but I’d check the level before starting on the fronts as I did drain it once.
AL.
_________________
Al Campbell
Offline Profile
Display posts from previous:  Sort by:
Page 2 of 2
16 posts Go to page Previous  1, 2
Users browsing this forum: No registered users and 1 guest
Search for:
Post new topic  Reply to topic
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
cron
