Re: Post some vids boys!!
Melvivio,
I haven't read the entire post. Just watched the video. Nice car, well done.
I note from the power, you get a front end lift with every gear change up.
That suggests to me that you suspension is too soft and damping rates are not high enough. Would that be you opinion too or is that how you prefer it?
Melvivio
Post by Melvivio »
Hey MD, I didn't build the car, So i'm learing the specs slowly.
On the ride quality, I'm not sure yet how I like it. The car rides fairly softly indeed, But for general road soft is fine. However it will probably under steer all over the place, when I go visit a racetrack in the spring.
So yes, I would like to stiffen it a bit, and try to find a nice balance.
The car is fitted with koni yellow all-round, and is lowered. Not sure how tight there shocks are set, they should be adjustable?
Within the next months a front 22mm (20mm now) antirollbar will be fitted, in rubber centre mounts (didn't want to go all the way with polyurethane), but connected to the ......? with uniballs. (Those will make it alot more direct, so thats why I chose 22, instead of 24mm)
At the back, a 22mm antirollbar is installed, and as far as I can tell, everything is in rubber bushings. (not powerflex, or polyurethane)
Of course goal would be sublime on the road & track, but that's not achievable.
So I prefer a bit stiff on rough roads and "good" on the track.
(in Holland in general the roads are good, and the seats are soft so that will balance things out)
However it will see more road tarmac then racetrack. I do not want to spoil the cruising ability.
lucass81
Post by lucass81 »
Great GTV6, one the greatest I´ve ever seen.
It sounds to good to be a 24v, most 24v sound to deep but this one sings!
Can you send a pic of the exaust from under the car?
84 GTV6
96 M3
Melvivio
Post by Melvivio »
Not that much to see. 2x 51mm tubing, front to back. I will install flex pieces in the near future. To pull the whole thing to the left a bit. And yes I know, I need to replace the input shaft bearing... oil spilling out of there a bit.
and here's why, it slams on the nipple:
The exhaust muffler itself is according to the builder, the muffler of a Maser Ghibli bi-turbo.
It does sound quite sharp and quite crisp. However I bought it was better. A "specialist" changed the timing belt, but did not use the camshaft locks to keep them in place. They locked the wheels.. It shouldn't make any difference according to them, but to me it feels and sounds slightly less energetic. Not sure if its possible, or it is in my head.
lucass81
Post by lucass81 »
Thanks! that was quick!
Whats wierd its that they never join! Nowadays everybody joins them with an X or Y.
84 GTV6
96 M3
Melvivio
Post by Melvivio »
No problem! When checking forums, why not reply!
It is indeed weird, but probably has a simple reason. In the end the car was drivable. So the end bit is a bit rushed.
I believe he had enough tubing lying around to make this... So didn't bother buying new or bigger pipes..
lucass81
Post by lucass81 »
I will try to make a video to post this weekend. I have the exhaust joined with an Y at the front.
84 GTV6
96 M3
I think you are probably better off with a Y type exhaust, you're probably loosing some hp's with your setup
lucass81
Post by lucass81 »
http://www.youtube.com/watch?v=jU14s5LYeuo
Here is a short clip on-board my GTV6 2.5. I will post more with better sound recording hopefully.
84 GTV6
96 M3
lucass81 wrote:http://www.youtube.com/watch?v=jU14s5LYeuo
Hey Lucas, are you on any of the Argentinian forums? I travel very very often to Buenos Aires due to work (Airplane Jockey hehe), love to meet up and get a coffee sometime!
lucass81
Post by lucass81 »
No, I´m not on Argentinean forums.
Sure we can meet, just let me know when you are around. I´wont be in Argentina from 11/02 till 28/02. And from 04/03 to 08/03 I´ll be in Punta del Este with some friends.
84 GTV6
96 M3
lucass81 wrote:No, I´m not on Argentinean forums.
Well my friend since you are coming to visit our beloved country we can arrange and meet up over here if you want, meet some other alfisti's from here!
kens
Post by kens »
Here we have the Lancia version of the AR 3.0 24V engine. In a FWD setup the engine sits very forward of the front wheels. So, in a mid-engine configuration the engine sits well forward of the rear wheels. Perfect!!!
http://www.youtube.com/watch?v=BW_2Vxkd72M
lucass81
Post by lucass81 »
Well my friend since you are coming to visit our beloved country we can arrange and meet up over here if you want, meet some other alfisti's from here![/quote]
If you guys are going to hang around Punta del Este, sure. But I cant go to Montevideo since I´m going in one car with 2 or 3 friends for only 4 days.
84 GTV6
96 M3
Cool, on the 25th we are meeting with the club, we might arrange a rally to punta del este in march, if not we'll meet in Buenos Aires, I go there quite often :D
