Building the supercharger to the engine (75 3.0V6)
Post by Jim K » Tue Oct 02, 2018 7:05 pm
Just measured several sets of used 164 24v gaskets (all in excellent, I would even say reusable shape) and they are all 1.6-1.7mm. I have a new set of special Nava ones still sealed, advertised as 1.6mm thick.
gtv-racer
Post by gtv-racer » Thu Oct 04, 2018 1:19 am
@ Remco:It is fore sure a 12v one since i never owned a 24v.
Finaly found some info on it on the web. There are 1.8 and 1.7 one's according to this site:
https://www.auto-onderdelen24.nl/alfa-r ... koppakking
Think the 1.8mm ones are for a skimmed head so i think 1.7 is original. 1.7 are the Reinz one's.
I tried to measure between the head an blok on the car. I was getting a reading of 1.8mm but it was a bit tricky...
gtv-racer
Post by gtv-racer » Thu Oct 04, 2018 1:21 am
Thanks Jim!
gtv-racer
Post by gtv-racer » Mon Jun 24, 2019 12:32 pm
I pulled the engine because I want to built in a baffle plate in the sump. Checked the crank when I was at it. Had it regrind.All bearings which where good stayed nice. The bad ones got worse.
Also the pistons which where coated gone bad. Coating was gone. All aftermarket and NOS piston and liner sets which I ordered where of very low quality.
0.1mm piston to liner clearance with some and 0.02mm ovalization and taper error or more.... sent them al back.
Now I'm exploring forgies. Some have a quench area but built for high comp ratio. I want about 8.8:1 to 9:1 so I need custom made ones.
Paul Spreull for example has high com ones with what is looks like a quench area:
I think it is nice with for me a disch in the middle to compensate cr. What do you guys think?
How much head to piston clearance should the quench area have..?
Tough questions I think.
Wossner does the same it looks like:
gtv-racer
Post by gtv-racer » Mon Jun 24, 2019 12:33 pm
Paul Spreull for example has high comp ones with what is looks like a quench area:
http://www.spruellmotorsport.com/piston ... -5301.html
https://lh3.googleusercontent.com/--_D7 ... C_0277.JPG
gtv-racer
Post by gtv-racer » Fri Aug 23, 2019 5:37 am
Nice stuff 8) 9:1 cr
gtv-racer
Post by gtv-racer » Tue Oct 22, 2019 3:09 am
gtv-racer
Post by gtv-racer » Tue Oct 22, 2019 3:10 am
Made a ring grinder for nice parallel slots:
Assembled the piston assembly:
Lathe down the flywheel:
Also assembled the the crank and rotating assembly
Minor progress but I hope things speed up now.
KevinR
Post by KevinR » Wed Oct 23, 2019 12:31 pm
Nothing like a new set of Pistons . What prop set up did you run with ?
Post by Giuliettaevo2 » Thu Oct 24, 2019 10:16 pm
Clever tool for the rings. :P
gtv-racer
Post by gtv-racer » Sun Oct 27, 2019 10:03 am
OEM prob setup with BMW middle donut. Never had an issue with it while drifting and racing it.
Hope this isn't going to be an issue with the new low comp pistons..
gtv-racer
Post by gtv-racer » Tue Nov 12, 2019 4:35 am
Made a sumb baffle plate :
Some engine assembly pictures. Race baffle also installed.
What crossed my mind is that i know a guy who retarded cam timing on his 75 super charged 3.0 with 6 degrees. He gained approx 60 hp. I think idle in my setup is gonna be the problem because it's already very hard to tune.
That make me think of variable cam timing. Is there some out there who did the same?
gtv-racer
Post by gtv-racer » Tue Nov 12, 2019 4:36 am
Post by 75evo » Tue Nov 12, 2019 6:36 pm
Whose supercharged 75? Is it the red one from Norway or the one Mende (DK) built and sold to someone in Taiwan?
Why would idle be difficult for your car? Aren't your cams mild?
