Variable TPS
Duk
Variable TPS
Post by Duk » Wed Nov 30, 2011 6:36 pm
I need a linear, variable TPS that will suit the (from what I've seen of 3 different make, Japanese car TB's ) opposite opening direction of the Alfa V6 throttle body.
A Nissan RB20DET engine TPS slides onto the Alfa shaft, but because the TB opens the opposite direction, the sensor would show a decreasing voltage to the computer as the throttle opens, and it can't be configured to work that way.
Any suggestions or links?
BTW, we really need a dedicated aftermarket ECU section to cover all aftermarket installations rather than just the 2 :wall: .
Re: Variable TPS
Post by Giuliettaevo2 » Thu Dec 01, 2011 12:23 pm
From what i've seen you need one from a 155 v6. That uses the same throttle housing and plate but with the linear sensor. :wink:
Duk
Re: Variable TPS
Post by Duk » Thu Dec 01, 2011 2:27 pm
Thanks Giuliettaevo. V6 155 aren't exactly common occurrences here in Oz (not sold here), do you have the Bosch part number? It is hopefully the same as another brand of car like a BMW or Merc.
Re: Variable TPS
Post by Giuliettaevo2 » Thu Dec 01, 2011 2:51 pm
I'll check tomorrow.. :wink:
scott.venables
Re: Variable TPS
Post by scott.venables » Thu Dec 01, 2011 2:57 pm
I've read about people using the Volvo 850 TPS. Sorry, not sure which engine.
Scott
Re: Variable TPS
Post by Giuliettaevo2 » Fri Dec 02, 2011 4:44 pm
The number on my 155 v6 sensor is 0280 122 001. Made by Bosch... :wink:
Duk
Re: Variable TPS
Post by Duk » Sat Dec 03, 2011 1:08 am
Thank you!!!! 8) :D 8) :D 8) :D
Re: Variable TPS
Post by fedezyl » Sat Dec 03, 2011 2:39 am
I'm pretty sure that the tps sensor out of año alfa 33 1.7 8v works, i used one for my 33 16v with Megasquirt and it was a direct fit, and the 16v uses the same tps than the motronic 164, it has to be from the series 3 33 1.7 8v without afm
GarthW
Re: Variable TPS
Post by GarthW » Tue Dec 06, 2011 2:03 am
I'll have a look at mine tomorrow mate, just seen this, mine's a Bosch as well and bought here of course.
Selling 1985 GTV6.
GarthW
Re: Variable TPS
Post by GarthW » Wed Dec 07, 2011 12:49 am
TPS Bosch Part number-1280 122 001 :wink: Only difference between Evo's is the #1 at the start, the rest is the same.
Sorry for double post. :)
Selling 1985 GTV6.
