280 Rear wheel horsepower on a low budget
Post by Greg Gordon » Sun Apr 29, 2012 7:25 pm
http://www.youtube.com/watch?v=epzfOY6t_WI
This guy bought my book, and built a budget supercharged engine. It has held up at at least two track events. It's using an Eaton supercharger from a Mercedes. It's mounted on the right side of the car and blows through an air to air intercooler into a reversed stock intake plenum.
The shocking part here, is that he lowered the compression by putting a 2.5 crank into a 3.0 engine. This is very unconventional, but somewhat surprisingly, it worked out well. 280hp at the wheels on stock components is pretty impressive.
Greg,
www.hiperformancestore.com
www.okinjectors.com
Michael
Re: 280 Rear wheel horsepower on a low budget
Post by Michael » Sun Apr 29, 2012 10:23 pm
Nice - that looks like TunerStudio - do you know if he is running Megasquirt?
Michael
1981 GTV6
Post by Greg Gordon » Sun Apr 29, 2012 10:59 pm
I am 99% sure it's Megasquirt.
Post by Giuliettaevo2 » Mon Apr 30, 2012 3:07 am
Using the 2.5 crank in a 3.0 has been done before.. :wink:
Stephan from Squadra did it a few years ago already on a 916 3.0 Spider. The 2.8 engine delivers an easy 330 bhp and 400Nm+.
dutch link. :wink:
And the SA 155 24v TT used this approach on a 24v 3.0. :D
One guy i spoke to was worried about the squish in the 12v heads but i can't see very much squish-area in the original design so i guess it's not too bad. :)
gtv-racer
Post by gtv-racer » Mon Apr 30, 2012 3:17 am
nice! What killed the engine? High revs?
Post by Giuliettaevo2 » Mon Apr 30, 2012 3:24 am
Engines i talked about are still in service... :?
Also no need to rev them hard since their turbo'ed. plenty of grunt from down low. 8)
Post by Zamani » Mon Apr 30, 2012 5:26 pm
This is Han's car? I like to see the video of this SC car going against Niclas Rosengren's super modified 3.0 12V (232 whp). Super awesome!
Post by Greg Gordon » Mon Apr 30, 2012 8:24 pm
I would like to see that to, although I know the SC/car easily takes the hp/dollar contest, which is my point.
Post by Mats » Tue May 01, 2012 11:27 pm
Zamani wrote:This is Han's car? I like to see the video of this SC car going against Niclas Rosengren's super modified 3.0 12V (232 whp). Super awesome!
It sure looks like Hans talking to the operator... Can't say I Recognize the car though, the Trollspeed sticker on the fender is interesting though, they make a lot of 700+ Hp RallyCross engines and the They were the ones who made the Pikes Peak engine for Per Eklund. Huge track record.
Post by 75evo » Wed May 02, 2012 12:53 am
Post by 75evo » Wed May 02, 2012 1:05 am
75s vs. 348s
I think I've posted this before
http://www.youtube.com/watch?v=sP0OiWoffeI
Post by Greg Gordon » Wed May 02, 2012 8:44 am
Yup, that's the car.
Post by la_strega_nera » Wed May 02, 2012 3:31 pm
Very nice.
I've often wondered about the 2.5 crank to drop CR - infact i even posed a question on another (non brand specific) forum asking about the outcomes of low boost, 9.5:1 3l vs higher boost, 8:1 2.8l.
One of these days I'll do something neat.
1966 GTV
1982 Suzuki "Bathurst" Katana
Post by 75evo » Wed May 02, 2012 3:54 pm
Greg,
Wasn't Hans' car a high compression 3.0 with forged pistons, but it didn't quite work out for him so he just put in a 2.5 crank to drop the CR?
Ben,
Isn't the days of the 8 or 7 CR days over? These days we're seeing superchagred S2000 with stock internals beating 360s.
I think with Greg's setup, good ecu, and good cooling a stock 3.0 12V with 9.5:1 can be in the E46 M3 territory, if the ring and pinion allows it.
For a road car, I think hi comp and low boost is the way to go.
Post by Greg Gordon » Wed May 02, 2012 4:59 pm
I don't remember Han's car having high compression. I think he built it this way.
I discuss the high compression low boost vs low compression high boost issue in my book. The short version is lower compression with more boost and timing is better for power. Doing it the other way around is better for everything else.
There is not much advantage on the Alfa V6 in going below about 8.5:1, at that point you can put in 20psi, enough to break everything. Plus supercharger efficiency starts to drop off pretty fast when you go much higher.
