Headlight upgrade kit and more
I am getting ready to release a headlight upgrade kit, hopefully I will do it sometime in June. The kit is done and has been on this car for a couple years. It works very very well, and it's set at exactly maximum legal brightness. We even have brighter bulbs for the outlaw types.
The kit has two outboard headlights with high and low beam functions, all wiring, relays, connectors, and instructions. It's possible to add two more lights for the inboard hi beams but I have not bothered with that. It's so bright as it is, and two more bright lights would get close to the alternator limits. (My car has a lot of extra electrics) The lights are cheap to replace, and a variety of bulbs are avaliable.
- HeadlightUpgrade.JPG (60.78 KiB) Viewed 12441 times
Yes, you can see from the rock chips in the front end of my car that I actually USE this car everyday, it's my supercharged GTV6. It used to be my dad's.
I am also working on a GTV6 gauge pod. The one in my car has 4 items, a boost gauge, supercharger discharge temp, a system light, and a switch. It could be set up in a number of ways and would be made to order. It's made from 1/4 inch alluminum so the gauges don't need any bracing behind them which makes things a lot easier when installing it.
- GTV6Dash.JPG (102.56 KiB) Viewed 12437 times
Greg,i am very interested in a solution to the pathetic lights on these cars,every gtv i've owned i put relay's on the headlights.i think it works well,until i get in a newer car ,and .so please more info.
cheers m8
cheers m8
86 GTV6 GP
90 164 (ENGINE DONOR)GONE !!!
2013 Mito for the Wifey.
86 GTV6 GP
Thanks for the feedback. The first kits will be sold here in the classifieds at a steep discount.
- Alfa GTV6 NZ
