81 us gtv6
Posted: Mon Sep 01, 2008 3:06 pm
does any one know how the 2 vacuum hose on this dist are supposed to be run?
the top hose on the plenum goes to the back of the diaphragm (furthest from motor)
and the hose running from the bottom of the plenum is going to the front (closest).
when I remove the top hose the rpms go down. and timing moves further ATDC ,past the correct timing marks. Is there away to replace any of this @#@#?
