ok the 83 gtv6 2.5
its got a new issue tho.."sometimes" it simply wont start..it might start off the CS injector and die and thats it!!!...pull the wires off the coil..swap the polarity try again..then with the key on swap em again and it will generaly start every time untill the car sits over night
it comes right down to the fuel pump NOT running after starting the car...but what in the world does the coil have to do with the non triggering of the fuel pump?
ive played with the AFM to confirm the situation..and only the coil wireing swap seems to correct it...im stumped!!
