V6 wasted spark setup question
Post by 75evo »
For the V6 wasted spark setup should I pair cylinders 3 & 4, 2 & 6 and 1 & 5 ?
Trying to convert mine to CDI this weekend sing 155 V6 coils and Autronic 500R
thank you in advance!
Re: V6 wasted spark setup question
Check under the hood of your moms 155 V6? :wink:
Or just check which other cylinder is at TDC at the same time as the firing cylinder. Those are a pair.
Post by 75evo »
Actually the coil already has numbers on it. hehe.
Now I need to figure out the 4 pins going into the coil....
Hehe. :)
One positive and three ground/signal wires? 8)
