Help with keys...
Posted: Sun Apr 20, 2014 7:12 am
by 1985gtv6
Hi. Picked up a 1985 GTV6 that had been sitting for a couple of years. The keys are lost. Can someone tell me if the key is the same for the doors and ignition? I'd like to take just a door handle/lock to a locksmith rather bring a locksmith to the car. Thanks!
Re: Help with keys...
Posted: Sun Apr 20, 2014 7:47 am
by kevin
No the keys are different . Doors and boot are same . Easier to take boot lock out but remember exactly how it went back .
To take ignition out you have to drill out a grub screw on the under side . These grub srcrews were designed to break off when you install the new locks .
Posted: Sun Apr 20, 2014 10:40 am
by 1985gtv6
Hmm. I don't see anything under the switch but column. There's a nub right behind where the wires go in that might be something. It actually looks like it would be hard to just remove the column.
Posted: Sun Apr 20, 2014 12:06 pm
by kevin
It can actually take 2o mins to take lock out . No need to take column out . Been a while but just use mirror to see the hole . I think its about 6mm diameter . Take plastic covers off but to remove top plastic cover just remove steering adjustment bolt . You will probably put bolt back so its rigid when you drill into lock . I have a few spare locks in my tool boxes . I will find a pic .
Some older GTV you had to cut some of the wires on the lock as as they did not have bayonet fittings .
Posted: Sun Apr 20, 2014 12:22 pm
by 1985gtv6
OkAy, that sounds right. I'm looking at the correct part then. I'll give it a shot...
Posted: Sun Apr 20, 2014 12:53 pm
by 1985gtv6
Got it! Took about ten minutes. I sawed a slot in the bolt (and column) and took it out with a flat head screwdriver. I can even reuse the bolt.
Posted: Sun Apr 20, 2014 3:34 pm
by kevin
Aha l great going . Definitely will try that on my next one as these locks do pack from all the years of work that's why if its good protect it with a relay .
