zambon
Flooding caused by injectors sticking open on cold start
Post by zambon »
My 12v 3.0 is flooding on cold starts. The injectors seem to be stuck open, but the problem is intermittent. I pulled the plenum and pressurized the system by holding the AFM open and it sounded like all cylinders were spraying fuel wide open. I took the fuel rail out and the problem stopped. I turned the engine over by hand and the injectors fired normally.
Does anyone have advice on diagnosing the cause of this problem?
Re: Flooding caused by injectors sticking open on cold start
Post by 75evo »
Sounds like an ECU problem. They do go bad, I had one go bad when the Milano was only 10 years old. Do you have a spare ecu to test? Or is the TPS somehow signalling a WOT condition?
zambon
Post by zambon »
Hey 75evo
Thank you for the reply. I put in a 2.5l ecu and the car started right up. I can’t remember what the differences between a 2.5 and 3.0 ecu are, but I’m happy that she is running again.
