Electronic Water Pumps
GarthW
Post by GarthW » Tue May 22, 2007 5:46 pm
Does anyone have a electric water pump that replaces the old mechanical water pump..? I was thinking about putting one in when rebuild starts, for apparently they offer more performance, well dont rob as much power as a mech one...? :?
Selling 1985 GTV6.
Post by Micke » Tue May 22, 2007 10:19 pm
I do but it is still sitting in the shelf. It should be mounted and tried out in a month or two.
Post by Mats » Tue May 22, 2007 11:27 pm
I've argued this back and forth with myself but I can't decide without testing what is the best solution. Obvoiusly the pump needs to be turning very fast when on full throttle because then you need maximum cooling so you might not gain anything. On the other hand all the mech ones are probably designed for maximum cooling at lower rpms so at race rpm they have a lot of over capacity or even cavitates...
I can tell you one thing though, a buddy had a weird over heating problem in his race car a couple of weeks back, EWP and so on. Only found the cause after he returned home, the alternator was shot. Didn't deliver as much power as needed to turn the pump fast enough, only almost fast enough.
Post by Micke » Wed May 23, 2007 1:09 am
I cannot imagine a big benefit using an electric pump.
Currently I'm running the stock pump at -30% with good results.
Post by Zamani » Wed May 23, 2007 10:32 am
-30%? Custom pulley for the pump?
grant
Post by grant » Wed May 23, 2007 8:58 pm
IF you're not overheating with the stock pump, what's the point? Is a water pump really a large portion of loss due to external parts?
Post by Micke » Wed May 23, 2007 9:28 pm
Custom pulley at the crank. Alternator turns ar -30% as well.
Post by Mats » Wed May 23, 2007 10:03 pm
grant wrote:IF you're not overheating with the stock pump, what's the point? Is a water pump really a large portion of loss due to external parts?
Yes.
Post by Micke » Wed May 23, 2007 10:36 pm
Also, if you ever drove a modern car with EWP, did you notice how fast the engine gets to operating temp. I was so astonished when my rental car once was immediately warm that I measured it. Less than a minute to get warm.
Re: Electronic Water Pumps
Post by 75evo » Fri Jun 20, 2014 12:16 am
This OEM pump is what I intend to use.
http://www.miataturbo.net/engine-perfor ... ler-69420/
The PWM controller will be this
http://www.tecomotive.com/en/tinycwa-en
