Page 3 of 4
Re: Alternative gearbox for 2.5 or 3.0
Posted: Fri Jan 30, 2009 12:29 am
by Micke
hmmm.... I didn't realize the 928 and 944 gearboxes are totally different.
I looked at this years ago and it's clear a 924/944 gearbox doesn't fit being behind the rear axle where the DeDion is.
But from this photo I see the 928 box is in front of the axle making it suitable to some odd project. It should cope with some serious power and torque as well.
Posted: Wed Mar 25, 2009 4:59 pm
by killaz
Have someone thought about converting to Sierra gearbox..?
Posted: Thu Mar 26, 2009 11:22 am
by Giuliettaevo2
Hell no..., better get yourself a Getrag 265 then. That is way stronger and shifts better also.
The bellhousing is the problem in most cases. For the Opel kadett from a friend of mine we made this:
it's an Audi S2 5 cyl. 20v turbo engine with a Getrag 265 gearbox. Later we found out that we could have used the bellhousing of an old Volvo diesel gearbox...
Or how is this for a work of art? uses some old american gearbox.
Posted: Thu Mar 26, 2009 12:28 pm
by erikswede
Way to go!!
You are making us all proud!
Posted: Fri Mar 27, 2009 2:26 am
by Giuliettaevo2
please note that the second one is NOT my work...
I believe it is part of the Bonneville Spider.
Posted: Fri Mar 27, 2009 3:18 am
Yep, hte artist is Jim Steck if I'm not mistaken.
Posted: Fri Mar 27, 2009 6:39 am
by killaz
Real piece of art!
Hm, I saw just right now that Barry mentioned almost straight fit Alfa sei bell + Getrag 265. What about diff? If there's no diff from Sei, must go for diff from bmw? Someone did that conversion already?
Posted: Fri Mar 27, 2009 4:20 pm
by Giuliettaevo2
The south africans have some beemer diffs in use...
Only problem i see is that the Sei diff has a long nose on it in order to get it over the front of the triangle. the beemer diff is rather short so you would have to take your propshaft over the triangle.
The Audi RS2/S2 Quattro rear diff also has a long nose and is a nice compact unit. maybe that would be easier to fit?
barry could shed some light on this probably but he hasn't been posting for quite a while now...
P.s. i might have a Sei bellhousing for you... no promises however.
Posted: Sat Mar 28, 2009 2:44 am
by killaz
I'm still just diging, collecting data and prices... Tried to find Getrag 265 over here and it's almost rare (drift boys started collecting them few years ago).
Meanwhile I'll start with rebuild of Transaxle 4.3 ratio, togeather with lightweighting etc.
Posted: Wed Dec 23, 2009 1:16 pm
by killaz
Posted: Fri Feb 19, 2010 4:29 pm
by xrad
is the Alfa v6 set up for front clutch? will the thrust washers handle the force? I don;t think they are designed for excess forward push on the crankshaft....
Posted: Fri Feb 19, 2010 5:41 pm
by fedezyl
xrad wrote:is the Alfa v6 set up for front clutch? will the thrust washers handle the force? I don;t think they are designed for excess forward push on the crankshaft....
They are used on the 164 and late 916 GTV with front wheel drive whith front clutch setup, so I guess they are up to the job.
Posted: Sat Feb 20, 2010 12:21 pm
by Giuliettaevo2
the Alfa v6 was first used in the Sei which had a front mounted ZF gearbox... Later on it was used in the GTV6.
by Giuliettaevo2
Posted: Sat Mar 20, 2010 2:20 pm
by TS_turbo
i can show pics of my buddy weird car how we attached bmw gbox to 3.0 164 v6 ... car is pure frankenstein e30 bmw ... 164 3.0 engine ... 75 de dion ... SEI 3.83 diesel LSD diff ...
