Author Message
<  Gearbox, Clutch and Driveshaft  ~  Input Shaft Affect Speedo Reading ?
PostPosted: Wed Feb 07, 2007 11:50 am
GoldGoldJoined: Wed Dec 29, 2004 5:55 pmPosts: 145Location: Marysville, WA. USA
Does the input shaft in the transaxle differ over the model years in regards to speedo readings? Is this were the sensor picks up the signal ?
My intention is to install a Milano Verde transaxle but with the earlier GTV6 trans housing in an effort to avoid speedometer compatibility problems as well as having to clearance the seat well if the isostatic linkage was used.
Thanks for your help everyone,
Merril
_________________
82 GTV6 3.0
Offline Profile E-mail
PostPosted: Wed Feb 07, 2007 1:00 pm
User avatarPlatinumPlatinumJoined: Sat Apr 23, 2005 11:12 pmPosts: 273Location: Brisbane, Australia
The speedo is "driven" (gear or pulse) by the output shaft.
If your GTV6 had a gear driven pulse setup (veglia?) then it won't interchange with the Milano/75 pulse setup (Jaeger?). You'll have to adapt it using a pulse modifier - there are a few threads covering these.
If you want to keep the old simple shift linkage (I did), you just swap the input selector shafts over. No need to swap the casings etc.
I think (but not absolutely sure) that the isostatic will fit with no body mods, I just didn't want all of the extra parts that wear and add slop to the change.
Offline Profile
PostPosted: Wed Feb 07, 2007 4:10 pm
User avatarGoldGoldJoined: Thu Dec 16, 2004 11:11 amPosts: 183Location: south FRANCE
:D ALL RIGHT
i'm 100% with you.
how much time we hear :
-non isostatic fitting is slow ..? just pull the stick faster...
-non isostatic fitting not precise in my old gtv... just rebuild you gearbox and check mounts !
i'm running an old fitting, and with everything working fine, is fast precise smooth and 100% effective, as much as an f1 box (~) 8)
_________________
2 stroke addict
Offline Profile
PostPosted: Wed Feb 07, 2007 6:31 pm
I've done a few things to make mine shift better.
http://alfagtv6.com/bb/viewtopic.php?t= ... cb97a4255b
I moved the shifter mount up so the pivot point would be higher.
I pressed the pivot ball up the stick so the bush at the bottom of the stick ended up back in the oroginal position.
I replaced that bush.
Then the big one is, warm up the gearbox before you try flying shifts. Once the oil in the box is warm, I can shift as fast as I want with no problems. Admittedly, I have good synchros.
Offline Profile
PostPosted: Thu Feb 08, 2007 1:05 pm
Thanks for the input guys. I'll swap the input selector and leave it at that.
I'm familiar with the speedo work-arounds so will employ a fix for that as well.
Merril
_________________
82 GTV6 3.0
Display posts from previous:  Sort by:
Page 1 of 1
Users browsing this forum: No registered users and 1 guest
Search for:
Post new topic  Reply to topic
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
