Ok I may humiliate myself here but anyway... All the stuff conneted with guibo types being changed over the years is vague to me... Can you tell that this is the "proper" rear guibo for 1984 Euro gtv6? Reason I'm ansking i wanted to install brand new rear guibo off my friend bought for his 1985 Milano and well, it wasn't quite a fit.
Well makes sense, afaik the weaker transaxle cars had the cheaper clutches with convex pressure plates (which is my case) as opposed to v6's turbos etc. If this is correct then someone had to chage the rear part of the driveshaft to fit the clutch? I kinda have a problem because when i want to order the guibo for gtv6 they all have diffent guibos listed...
