Hi all, I have been offered a set of these going spare, and wondering weather to go for them or not.Im not sure what they are worth. I currently have the RS front brake budget upgrade with 305mm/28mm thick discs and brembo caliper spacers. Would these GTA calipers be an improvement over the original GTV brembos? will these be compatible with my current discs, and what will I need to adapt these to GTV6 hubs?
thanks.
147/156 GTA phase 2 calipers
- calipers.JPG (37.67 KiB) Viewed 6370 times
Brembo 4 pot caliper adapters.
Hi there, I've got the same caliper/disc combination (not yet fitted!!) and I wondered does any body already produce the billited adapters for these calipers to bolt to 116 GTV6 hubs. Any other advice on hub height and other associated modifications would be a bonus...
THanks G
THanks G
