Bruce
v6 clutch release bearing
Post by Bruce »
.. a famous person from Sweden once said these bearings are NLA, I think he's right, so, what options do I / we have?
Re: v6 clutch release bearing
You may need to get a machine shop to make you a bearing carrier to fit another bearing type that will do the same job. It is common practice to do this so there should be no big dramas.
Bruce
Post by Bruce »
I'm pretty convinced the Sachs pressure plate is not unique to this car. I am thinking circa 70's Porsche 911 or may be a VW. The release bearing I can get welded / repaired but my car is a daily driver and a need a replacement pretty snappy.
