An original GTV6 3.0 entry into SA Marque car category
This is new Entry into Marque car catregory here in South Africa9pre 1985) . Basic rules are you have to keep full interior , same engine and drive to the track . In otherwords its a compromise class but its huge challenge to get the heavy GTV up to the front with the 2.5 motor. The original 3.0 motor was taken out by previous owner .
At this stage all finances are going into the handling,brakes ,safety and all other perishable seals , hoses etc. Once this has all been tested and car is set up then engine work will start as per JK BOOK
The car belongs to a friend of mine and I am just assisting to get it onto the grid .
Some pics to follow of its proggression . It will be fun to follow this thread throughout the year to see when this car ends up a fullblown race car.
The owner is a very accomplished driver so it will be more about car set up before motorwork takes place. He won this series in a 105 series gtv so it will be a hard task to follow with the 116 gtv.
RS suspension has been fitted , braided hoses , ferodo discs and race pads.
Exhaust has beenn a bit testing at the moment but will discuss later.
See all oil plugs have to be wired etc
- giuflexi.jpg (67.92 KiB) Viewed 13217 times
- giuexhs.jpg (69.34 KiB) Viewed 13217 times
- giuwatts.jpg (58.91 KiB) Viewed 13217 times
- giufrontrs.jpg (64.18 KiB) Viewed 13217 times
Re: A new GTV6 2.5 entry into SA Marque car catergory
Pics of the car itself. This bonnet or hood comes off my old TT GTV hence the air ducts. This car was a genuine GTV 3.0L but the engine was changed by previuos owner to 2.5 and injection fitted so we had to remove the fiberglass "bulge' bonnet. Also the reason why there are the original red striping on the trim . The bodywork has just been touched up and trim will be completely fitted later .
Owner will join forum to continue this build soon .
- giusdriveupwards.jpg (114.69 KiB) Viewed 13215 times
- giuboltcage.jpg (82.46 KiB) Viewed 13215 times
- giubonnet.jpg (71.7 KiB) Viewed 13215 times
- giuside.jpg (90.89 KiB) Viewed 13215 times
Hi All.... I have been "snooping" around on this forum for a while and have decided it is time to reveal myself .... my name is Giuseppe and I own this GTV (an original 3.0 SA car, but with a 2.5 motor put in by someone at some stage)... Thanks Kevin for the info and the help so far, I must say that without it I would not have been this far... These cars are VERY different to the 105 I raced!!!!
Anyway, I will be adding some more pics as things progress, the intention being to make te first event of the year at the David Piper at end of January at Zwartkops
Hi All - some more pics attached below - then the final stages to be done to get the car ready for January race - to be done still:
1) Race seat
2) Race Harness
3) Fire Extinguisher
4) Remove Brake Dust Covers
5) Adjust exhuast as it now touches on new WATTS link (RS)
6) New wheels and semi-s;icks to be fitted
7) Re-fit and "cut" rear seats
Hold Thumbs
Thanks again to Kevin and this forum that has been very helpful...and other guys who have helped along the way - Prop, Suspension, exhaust, etc...
more soon..
G
1) Race seat
2) Race Harness
Hold Thumbs
more soon..
G
- all the trim is back
- photo5.JPG (140.39 KiB) Viewed 13152 times
- most of everything now back in, except rear seats
- photo3.JPG (136.14 KiB) Viewed 13152 times
- another view of cage and NO seats
- photo9.JPG (133.2 KiB) Viewed 13152 times
- roll cage welded in
- photo7.JPG (146.42 KiB) Viewed 13152 times
Another bit of progress....Dust covers now off...Thanks to Mr Rascher!!!! -
Next week will be going to look at various seats!!1
G
G
- Dust covers now off...thanks MR Rascher!!
- photo 10.JPG (84.07 KiB) Viewed 13133 times
Yeah it was good to see the old man getting stuck in - removing dust covers.
This roll cage was a bolt in cage with the rear section now been welded in and extra bracing added. As mentioned it's a compromise class so you cannot weld the entire cage in . The cage has been tied at b pillar to just above seet belt and then directly off that point at 45 degree angle to the tunnel. At least the rear section of the cage is tied into body.
Faaaargin prop is giving us stress at moment . It does not vibrate at all right through the rev range but has clanging sound from front .( maybe it's not - just noise transferr)
Prop been out 3 times with a completely new bush in front now. Sounds as if the pinch bolt on the yoke is not tightening or something is pressing against the front of the bush in flywheel so the bearing is sitting in middle of the bush .
Hopefully some one here might have some other ideas . Please let us know
Hi
Right - so below is a pic of the wheels that will go on....Compomotives 15" 7J -
BUT, as in previous post, the prop is a major concern!!! a "tiiingiiing" noise at low revs or as we switch off engine...
- Compomotives 7j15"
- photo 11.JPG (114.91 KiB) Viewed 13103 times
Hi All (from a HOT and sunny SA)......
We have made some GREAT progress since last update - again thanks Kevin and Mr Rascher, your help has been awesome!!!!!!!
We have now succeeded in getting the following done:
1) Cage is complete - all welded and bolted
2) Race seat and all bolting for seat is done
3) Harness is in
4) Steering wheel is in
5) Extinguisher is in
6) Exhaust all sorted
Sounds like a little, but it has been one HUGE battle and task!!!
see pics!
3) Harness is in
see pics!
And the pics
- steering Boss
- upload5.JPG (108.81 KiB) Viewed 13024 times
- The steering wheel - Momo 350mm
- upload4.JPG (129.26 KiB) Viewed 13024 times
- The seat itself = sabelt
- upload3.JPG (126.3 KiB) Viewed 13024 times
- Steering wheel adjustable spacer - 20-80mm
- upload2.JPG (102.99 KiB) Viewed 13024 times
- Seat anchors
- upload1.JPG (133.32 KiB) Viewed 13024 times
Some more pics
- Front suspension details
- upload9.JPG (105.35 KiB) Viewed 13024 times
- front brakes again
- upload7.JPG (119.75 KiB) Viewed 13024 times
- Rear Watts Link - rose bushes
- upload8.JPG (92.43 KiB) Viewed 13024 times
Hi All
MAde some more progress.... getting close to scrutineering now...which is next week saturday!!!! - then the next week is the David Piper International!!!!!
I have attached a few more pics
- Rear seats are back!!!
- photo23.JPG (137.23 KiB) Viewed 12950 times
- Interior now "complete"
- photo21.JPG (113.77 KiB) Viewed 12950 times
- Wheels are now ON!!!!!
- photo22.JPG (136.4 KiB) Viewed 12950 times
It's finally getting there , not been easy though . Always picking niggles with fitting items while trying to keep full interior . Items like fitting hooter, seat, fire ext, bonnet clips have taken longer than fitting whole supension . You see us really bending the rules by cutting the rear seats to fit around the existing bolt in roll cage which was modified with a couple of extra cross braces welded in in.
Roll cage is not pretty but B and C pillars are picking up the load points nicely and are welded to the body.
Joe you need a sound clip of this motor , absolutely music - typical 2.5 sound with base
This is a really cool build!
Hope you can at some stage get a 3.0 Carb motor back in it.
Hi
Thanks .... The thought of getting a 3.0 back in has definitely crossed my / our minds a NUMBER of times!!!!! - The first stage is to get the car ready to comply with the rules and on to the track.... once that is done and niggles sorted, which I am sure will take their own time , the plan is to look at getting it back to "standard" 3.0 ltr..... Carbs, Motor, Hood, front air dam, etc.....
Will take a while,,,..... Yes - sound!!! - ok, will do!
A few more pics of some stuff done + "when I grow up....."
- Fire-extinguisher fitted...
- photo26.JPG (137.2 KiB) Viewed 12902 times
- When I grow up I want to be!!!!! - no points for guessing to whom these wonderful specimens belong!!!!!!!
- photo24.JPG (110.81 KiB) Viewed 12902 times
- Cable from "In-car" kill switch to external knob + dials (Oil Pressure and Water Temp)
- photo25.JPG (76.5 KiB) Viewed 12902 times
