Describtion of next steps, ...
Installation of cam sealing rings and turning crank to TDC position of Cyl. 1.
- P1030152.JPG (229.25 KiB) Viewed 17143 times
Installation of adjustable cam pullies and timing belt (cam pully screws still open so cams can be turned).
- P1030153.JPG (211.85 KiB) Viewed 17143 times
Installation of Front Pully.
I´ve made a plate for the dial gauge which I can fit on cylinder heads on inlet and outlet sides.
I´ve started with adjustment of lift on cyl. 1 Inlet valve at TDC cyl. 1 according data sheet of Cat Cams.
- P1030157.JPG (253.29 KiB) Viewed 17143 times
- P1030158.JPG (217.85 KiB) Viewed 17143 times
Adjustment on cyl. 1 Outlet valve at TDC cyl. 1 according data sheet.
See the Overlapping !!!
- P1030159.JPG (243.03 KiB) Viewed 17143 times
