Re: Mats Strandberg (SWE)
The e90 is actually a vey nice car to drive. The steering especially is leaps and bounds above the e36. The only thing I dnt like is the Inline 6 is the sound, a bit too ....well it's not an Alfa V6.
- Maurizio
Mats wrote:I have a benchmark corner I use to get a feeling for how well the chassis work.
With my old 9-5 I could enter at around 90kph, my whole body screaming "you're going to crash!", the 155 V6 manage around 100kph with a slight drift really on the limit...
My E91, the 320d touring I entered at 110kph first time without even thinking about it, mid corner I realized I was going pretty fast and glanced at the speedo.
My point is that che chassis inspires confidence and is very competent, it's just THAT good. But you say it's boring because it's too good? You need some quirkiness to keep your adrenaline level?
I drive daily a 118D and I have a similar corner and a very twisty / bumpy road to test around here. (no not the n'ring)
And I was surprised to see what speeds I was doing the first time with the bmw wrt my n'ring 75 ts.... (and that is a trackday car)
To me the 1series is an evolution version of a 75.
Stil love the alfa's, but I guess, was I brought up between bmw's... I wouldn't have an alfa bias.
Same with vw / porsche what ever... you just simply don't switch that fast because of the history, the clutter, parts, experience and the community you grew up with
Isn't that implied when u drive an alfaYou need some quirkiness to keep your adrenaline level?
Bmw and other german brands in their factory states inspire "false" confidence for me, it's too quiet, to refined if u know what i mean... They are good cars, no question about that, they just don't get my juices flowing when u put your foot down or point them to some curves. Otherwise great choice. Wish u many happy km's in it.
Pulled the propshaft out this Sunday, the whole job took about 4 hours.
That includes putting the car on jack stands, the exhaust, heat shields and other covers and the prop itself. Had not done any of those things before.
On the Alfetta I would still be swearing over the exhaust or possibly the gearbox.
It's quite nice when you don't have 100mm long fixed studs overlapping and a welded centre bearing bracket...
Did kind of recognize parts though as the props have two guibos.
- Maurizio
ah, bmw is not only fun.
Go ask any E87 diesel owner about changing an air filter.....
wtf 2.5 [m^2] disassembled plastic and stuff on the garage floor.
And still how the hell do I get this thing out
Well, this is not something I didn't forsee. I knew there was a bit if wrenching to do and this is nothing compared to an old Alfa. Everything is available to buy and the parts catalog is available online and arranged in a very logic and easy way. I'm just buying all new fasteners as I replace parts. Costs nothing basically.
Compare that to, for instance, the halfshaft screws on my Alfetta. NLA for 20 years and they need to be replaced every other time you remove the halfshafts which tend to be VERY often when you're racing.
So far everything is great.
Also, Ring trip loosely planned for second week in July.
Who will be there?!
Who will be there?!
- Maurizio
you are referring to Sa 18th & Su 19th?Mats wrote: Ring trip loosely planned for second week in July.
Who will be there?!
That is a long weekend with the track open on both days from 8 to 19h. (ie will be a busy day on the track = a lot of track closers)
But maybe an interesting addition, the same weekend (17-19th) is in Spa, the dutch Alfa Romeo challenge driving. You are in the neighborhood when you are at the N'ring
Check, both in my agenda.
I wrote week, not weekend.
Spa would be fantastic, would it be possible to get some track-time you think?
- Maurizio
Of course, Spa has also trackdaysMats wrote:I wrote week, not weekend.
http://www.rsrspa.com/calendar?t=full&m=7&y=2015
http://skylimitevents.com/section/pages ... hamps.html
http://www.spa-francorchamps.be/en/trac ... rience.php
Cool, will check out those links.
This is quite a fast NS SA lap...
http://youtu.be/cp-KRcEpQEM
Check out the speed in pif-paf, Lauda links et al. Scary!
- Maurizio
btw where is pif-paf? You are referring to miss-hit-miss?Mats wrote:Check out the speed in pif-paf, Lauda links et al. Scary!
100 [km/h] difference wrt to a 75TS in Kesselchen...
Pif-paf is the left-right before miss-hit-miss. You know, bwaaaaaaah pif-paf bwaaaahhh...
- Maurizio
between Kallenhard en Miss-Hit-Miss is from 2.24 to 2.26 ==> https://youtu.be/cp-KRcEpQEM?t=2m23sMats wrote:Pif-paf is the left-right before miss-hit-miss. You know, bwaaaaaaah pif-paf bwaaaahhh...
Not sure if anyone cares but I'm going to update you anyway...
I've started to put the car back together now.
- All the new parts, well almost. Forgot the subframe bushings. Quite a few parts!
- image.jpg (235.27 KiB) Viewed 8715 times
- Replaced everything from the shift knob to the shift axle going into the box, very nice and tight now. Also new handbrake grip (and handbrake cables)
- image.jpg (168.89 KiB) Viewed 8715 times
- KW Competition in place, new wishbones from M3
- image.jpg (239.88 KiB) Viewed 8715 times
- Top mount
- image.jpg (153.62 KiB) Viewed 8715 times
Mats , did you use full rebuild kit for your gear linkage shaft . As I have similar gearbox from the e46 in my GTV it made a big difference if it is worn just to replace the nylon washers on the linkage bar .
