Duk
Re: transaxle upgrade's
Post by Duk »
Looking at a workshop diagram of the gearbox, the thrust loads from the pinion gear are fed into the case via the centre plate.
It doesn't matter where the thrust bearing is on the output shaft, so long as the shaft, bearing mounting point and the case in general are suitably rigid.
Your idea about an additional bearing near 2nd gear is interesting, tho. The shaft is pretty thin in that area and may bennefit from some extra support.
105gta.
Post by 105gta. »
I understand the thrust load goes into the intermediate flange but I feel with the gear sets trying to push away from each other and the added thrust also trying buckle the shaft it would only compound the forces involved.
Take a piece of string and lay it straight on the table. Try to push it from one end. Natural tendency to buckle. Up the test and stand a chop stick on the table and put your body weight or part there of on the end now apply some side load( gear forces) and see what happens.
I feel by adding a bearing mid way, it will help stop this effect and by moving the load carrying bearing to directly behind the pinion it will eliminate/minimize any distortion being both by load and temp change. By making the plate bolt around the bearing and right at the edges as close as possible to the case walls/Diff bearing. Distortion should be at a minimum. In relation to the pinion alignment. I think it would be about as good as it could get short of making an entirely new case in which case you'd just buy a hewland.
The idea is to shorten the load path. As is the case in most modern designs I have looked at.
As standard. The load goes the length of the shaft, across the int flange and back a long the case to the diff housing bearings. Any distortion or flex in any part along the way WILL have an effect on pinion alignment.
gtv-racer
Post by gtv-racer »
I'm sure your solution is the niced way to go an it also crossed my mind. The only problem with this solution is that the place to machine in a thust bearing, near the
diff, is very difficult because of the depth in the case. Long tools to reach the plane to machine and a thick plate should be used. Is there any room for that?
That's why i chose this way.
The extra support bearing is a nice idea! But how you gonna mount a support plate? Tryed to weld the case but it failed. Then again i'm not a pro welder. :|
Maybe i produce a coupe of flanges but they're not cheap. They are a full day of work and the material cost arealso high. Think in the 500 euro range... :oops:
I think my solution is a verrry nice one. Not perfect but surly educate. I have no problems so far with my original transmission and i drive it hard. Only no burnouts. But it will fail at one time...
The case brace is still an issue. The design is difficult if i want it to be good enough for torsion. Little space to few mounting point in the original case. One for clamping is easy...
Niced is of course both...
If i only had a picture of the glenwood brace to help me out...
105gta.
Post by 105gta. »
Gtv-racer, your int flanges a nice piece indeed. And I think it will help, I'm just sharing my thoughts and opinions
As for the support bearing. No need to attach it to the case at all. It's fiction would be to stop the shafts moving away from each other not tie them to the case. You could machine a small plate the fits between the bearings (think of a letter 'H'with a bearing cap on either end to enclose the bearings. Being rather thin I plan to double bolt each bearing cap similar to a 4bolt main bearing cap in a V8. You could either use long bolts/studs or bolt them into the Centre section. I prefer the idea of long studs with nuts either end or cap screws as there would not be much material to cut a thread in the Centre H section. You could under cut the 2nd and 3rd gears and use a wider bearing, the clamp force of the caps would stop the support from axial wander, say a 10mm bearing and a cap that's 6mm wide.
It's only function is to oppose the shafts from flexing. I'm thinking of using chrome moly plate simply from a strength per size factor.
For your case bracing have you looked at the diff side plate. The removable one. I know it has a lot of robbing but seeing your int flange you made. I would consider making a revised diff side late which incorporates som mountings for he bracing. As any flex there will also alter the pinion mesh. And also for the other side axle bearing. You could machine a new one the extends forward to incorporate mounting on that side for the brace.
Just some ideas for you to think about.
gtv-racer
Post by gtv-racer »
I think space is to small for puting in an axtra bearing to connect the input shaft with the output shaft.
The bearing needs the same radial load specification as the one in the intermediat flange.
This is because it will take most of the radial load of second and third gear. So you can not just put a small bearing in there..
105gta.
Post by 105gta. »
Yes space is at a premium for adding a bearing. But it is possible with some careful machine and spacing/moving of gears. I don't think the radial load will need to be that hi. It's only helping not the primary load carrying bearing, in theory it would only have a load applied under hi power situations when the shaft would be deflecting, most of which would be supported by the original bearings like a standard trans, this bearin would only be aiding/assisting during extreme conditions.
gtv-racer
Post by gtv-racer »
I don't agree on that. Look at it this way.
It is like standing on a beam with three legs. The one in the midle, where you stand closed to is gonna carry most of the load.
Not the one at the ends.
105gta.
Post by 105gta. »
Yeah I agree with that. Using your example. If the same beam had only 2 legs, and 100kg in the middle assume each leg carries 50kg. If you placed a third leg in the middle at the load it theoretically would carry 33kg as would the other 2, 'if' the beam had infinite stiffness. But we know it will have some bend/flex etc so it will be a little higher. In our case. If machined accurately the Centre bearing would carry neglible load as the shaft should be running true and our new bearing should be virtually idle under most conditions, until enough force is applied that the shaft would normally start to deflect then our new bearing would start taking up some of that load. Not only taking away from the end bearings but also maintaining shaft alignment.
Just my theory and ideas on how it would work. After studying many successful gearboxes I've noticed that most seem to use many bearings close together unlike our gearbox that has bearings at a fair distance apart as well as the main shaft serving 2 purposes and also taking the load of the pinion pushing forward only complicating the matter.
Compressive force on the shaft and side loading at the same time on a long shaft with bearings far apart... Ok for its intended purpose but not hi power racing.
It's the nature of the synchro design that is at fault in that it is a parallel type synchro, you must move the hub the full width of the synchro to achieve engagement or dis-engagement unlike modern cone type systems that can move bearly a mm or so and go from free to locked solid. Adds length to the whole system but we are stuck with it and have to try and overcome it any way we can.
gtv-racer
Post by gtv-racer »
I discussed the problem today at work with or engineer. And he is a verry good one!
He sad almost all power is translated in the extra bearing.. It is to the fact that even a small movement in axle centreline displacemt, beacuase there isn't any room to displace, will not bent the axle becuase of the third bearing. So the other bearing don't carry the push away from each other load.
But now the good news. Those forces are small in the plane that pushes the axles away from each other.
So we can get away with a small bearing!
Force F1 pushes axels appart
Force F2 bends the axles in the other plane and is the big force where alfa engineers calculated bearing load for.
So if we only have to support F1 we can get away with a small bearing. That's nice!
The F2 force is translated in twisting the axles around each other instead of flexing away in the F2 force direction because they are tied together.
The twisting results in extra pinion crown play because of original bearing positioning. The question is , how much... I think it is minimal but let's think a few days over this one for sure :|
105gta.
Post by 105gta. »
Nice work. I agree, I think that f2 would be the biggest force but have the least effect as well. For that to happen the shafts would have to stretch in length which is unlikely, and if they do then there is very little we could do about it other than tie the new bearing to the case somehow. Which would be rather difficult. I believe a floating tie/support to keep the shafts at a set distance apart would be the best bang for buck/effort.
gtv-racer
Post by gtv-racer »
Measure results of the billet aluminium plate are a 37.5% increase in bent stifness.About 0.045 movement That's not bad. I aspected a little more because of the better material and the not weight saved part.
Duk
Post by Duk »
gtv-racer wrote:Measure results of the billet aluminium plate are a 37.5% increase in bent stifness.About 0.045 movement That's not bad. I aspected a little more because of the better material and the not weight saved part.
An excellent improvement!
Would it be worth while to make a new bearing retaining plate from a higher strength, stiffer material (Titanium maybe) and make it as thick as possible?
gtv-racer
Post by gtv-racer »
the only thing this plate is better is because of that it is solid in learned today. The E-modules for all aluminium types is about the same.... Thats why the increase is
about 37% and no more. The higher tensile strenght doesn't do anything... Of course it is good for the bearing lip though that breaks out sometimes
under high load.
So if we want more improvement whe surely have to switch material. And then watch the E-modules number.
I think this plate is nice anyway. The gearbox held up to the job so far with not dumping the clutch all the time but hard
street diving was done for about 4000km. Mabe i'll make a long stud between the pignon bearing and the intermediate flange to beef up the plate a bit more if there is any room. This will make an internal clamp for the gearbox halves and an anti flex part for the flange :)
Duk
Post by Duk »
So either make an alloy steel 1 of go completely mad and actually create a carbon fiber bearing plate????
If it was made solid like your custon plate, it wouldn't be very light. But it would resist deflection like (basically) nothing else!
How thick is the central plate?
gtv-racer
Post by gtv-racer »
Carbonfiber would be nice but i think nearly impossible... the plate is 30mm thick
I think the studs i might place are making the new plate a lot better. But there might be a room issue... it is crowded in there.
