Few questions for spring rate (without torsion bars)
Please advise me on this topic>>
Car will be used for occasional track days and it should be driven to track.
Can anybody recommend me spring rate and length for front coil over conversion but without torsion bars? I would like to take them out. Feel should be similar to RSR kit (600lb/in) + torsion bars.
Re: Few questions for spring rate (without torsion bars)
Suggestion is a 165 kg /cm spring that is 150mm long and 20 kg helper. I run 200kg which is same as 33.6 mm torsion bar .
You will have to open up your upper control arm . I can send you full specs of my bilsteins
Please do send!
I suppose that helper spring is 4' long and ID of springs 2,25'? I've already opened upper control arm and tried some weaker springs (60kg/cm) with torsion bars, but it doesn't feels good enough..
What about reinforcement of chassis?
Thank you very much!
my mail: Lakijanovic@gmail.com
- scott.venables
Hi Kevin. Could you please email me those details as well? Do you have a dyno graph or is it a parts list?
my email is
djsav88 (at) hotmail.com
Thanks, Scott
my email is
Thanks, Scott
Hi Scott, killaz I am back home tomorrow so I will mail you all the pics and dimensions of front coil overs . I can't post pics so maybe you can put them up until I get my laptop back
Thank you very much for pictures and measures, they help a lot! ![Smile :)](./images/smilies/icon_smile.gif)
Killaz you welcome to post those pics on forum if anyone wants . I unfortunately have my shock dyno graphs mixed up with my old ones . I will contact the guys at bilsteins if he remembers what it was which I'm sure he does . ( sorry Scott)
- scott.venables
Hi Kevin. If you've got the graphs that's great, if you don't, no big deal.
Cheers, Scott
Cheers, Scott
C/P from Kevins mail:
52mm diameter
![Image](http://www.dodaj.rs/t/2N/uE/1NUEpsc1/img-20120318-00013.jpg)
Shock body 215mm long
![Image](http://www.dodaj.rs/t/1t/U5/1hqGWWR2/img-20120318-00014.jpg)
Hat to centre of pin is 60mm . I would change to 50mm . Means you can get car lower without touching steering arm
![Image](http://www.dodaj.rs/t/15/S5/2Pc5V8bJ/img-20120318-00016.jpg)
Travel to bumpstop is 85mm . Bump stop is 15mm
![Image](http://www.dodaj.rs/t/1X/N9/2oKUzKRR/img-20120318-00017.jpg)
Total shock length is 380mm BUT would reduce botton hat clearance by 10 mm
![Image](http://www.dodaj.rs/t/3J/fd/1SpwGvAy/img-20120318-00019.jpg)
Helper is 80 diam 60 long and 20kg (I suppose that diam is 60 and 80 is height)
![Image](http://www.dodaj.rs/t/35/Yk/1QXGaKmh/img-20120318-00020.jpg)
RS Bracket
![Image](http://www.dodaj.rs/t/1k/MZ/3l8FmzVL/img-20120318-00022.jpg)
52mm diameter
RS Bracket
Maybe a dumb question... Is it safe to make thread on regular B46 Bilsteins and convert them into coilovers?
Edit: Definitely no, there's no enough thick wall for thread.![Smile :)](./images/smilies/icon_smile.gif)
Hi!
Can someone insert the full spec of the setting?
Thank you
Manuel
Thank you
Manuel
