Guys, i'm looking for some advice, my Giulietta V6 is running now and waiting a few weeks for the supercharger kit from Greg to arrive.
In the meantime it's getting tested in some track days and we found there could be room for improvement in the front wheel alignment.
Current suspension specs are:
30mm front anti roll bar
Std rear anti roll bar
28mm torsion bars
Koni yellows all round (I know they are crap and they will be changed soon for a set of bilsteins)
rear springs from performatek that matches the front torsion bar's stiffness.
Center De Dion bushing replaced by RZ uniball and all poly bushings in the watts links
Std bushings up front
Basically looking for someone with a 75/Milano with sort of the same setup as the Giulietta has the same wheel base.
Thanks!
Re: Alignment for track/road Giulietta 116
My set up on a road going Giulietta with TS was almost the same. 30mm AR bar with rod ends, stiffer short rear springs.front end lowered a lot (2 teeth).
Set max caster. your front shocks are the limiting factor, they will hit the upper arm. You should be able to get like 6-7 degrees caster.
I had 3 degrees camber in front and zero toe. car handled perfect for my driving. very neutral going into oversteer when pushed to hard. but all settings are my preferences, you might want other settings to have the car behave like you want it too...
Annoyed many owners of 'fast' modern cars with it.
Cool, thankss, keep the input guysss!
