Alfaaa1
front wheel rim fouls the sway bar lower mounting stud
Post by Alfaaa1 »
Hi to all,
Just about another year gone.
Just noticed on my Alfetta GTV when I steer full lock my front wheel rim fouls the sway bar lower mounting stud,
Has any one had this issue as I see there are no steering stops. :(
Alfaaa1
Re: front wheel rim fouls the sway bar lower mounting stud
Post by Alfaaa1 »
It must be my Simmons rim offset, :(
Can someone confirm the standard Alfetta GTV front wheel rim offset .
KevinR
Post by KevinR »
Hi, yes you definitely get this problem with certain wheels I have tried. I have stuck with 25 offset on the 7.5j wheels. When i widened to 8j I added to the dish but then had to cut the body work. It’s a race car so it was neatly done and had no plastic sills. I can’t see anyone go wider than 7,5 J on 15” with out touching “ something “
What’s your specs ?
