Carl Friedman
Will 164S wheels fit on Milano?
Bolt pattern is apparently the same. Will offset be an issue? Also, will hub opening fit, was told the 164 hub opening is smaller than Milano.
Carl....in Virginia
Carl they fit just fine>i use 164S wheels for my track tires and they are excellent - light and strong.As Sam said the only mod is you have to take a Dremel to the center-bore I can't recall the difference but the 164 is slightly smaller.Takes a couple of minutes per wheel.Offset is fine.
- 164Swheels1.jpg (10.81 KiB) Viewed 5027 times
Carl Friedman
Thanks gents
I'm new to Alfas, been doing Fiats for last 20 or 30 years. Mine is a Milano gold with 5-speed and is dead stock except euro down pipes which previous owner fitted....which is why it probably just flunked emissions....no cat.
Friend with 164S is selling his stock wheels and I'm interested, at least now I know they fit.
Carl....in Virginia
