tectoteam
coilover ... where renforceing the chassis and fender aeras?
Post by tectoteam »
hello...
i want to rid of the torsion bars.
planning for the rs setup for the end of the year.
the car is a pure fun car, runs on the street for the fuel pump only, and often the times on track days.
does anybody had photos of reinforced fenders ?
i guess some welding beetwen inner fender and shock mount chassis frame :?
+ a renforcing upper bar.
look in the photo from a other car, about the solders points.
opinions ?
2 stroke addict
Paul Bird
Rs coilovers
Post by Paul Bird »
Hi, I have the Ron Simmons coilover ste up on my 3.0L GTV6, this set up was made to work along side the torsion bars not without them. If you use the colovers without torsion bars the car will not respond correctly. Put the lower front wishbone down one notch, this will lower the car down so you can adjust the ride hight using the coilovers.
Paul.UK
tectoteam
Re: Rs coilovers
Post by tectoteam »
hello paul
Paul Bird wrote:If you use the colovers without torsion bars the car will not respond correctly
Paul.UK
wasn't that Ron simmons says me...
also...car is welded...(only on front)
around front fenders and shock mounts.
i hope for a weigth loss of 30kg with tube welded A arms and RS coil overs.
2 stroke addict
ar4me
Post by ar4me »
So, what kind of spring rates are you planning on using up front when you ditch the torsion bars?
tectoteam
Post by tectoteam »
im planning on nothing, i follow the instructions.
the car is only for track days but not for race
RS racing suggest me 200 to 250 kg for front.
it sounds correct...
2 stroke addict
ar4me
Post by ar4me »
I'm sure Ron knows his stuff.
I'm just curious to how much it takes.
tectoteam
Post by tectoteam »
yeah.
for v6 heavy gaming.
Ron says: 100 to 150kg with oem torsion bars
and 100 more without torsions bars.
2 stroke addict
Maurizio
Post by Maurizio »
I did once a estimate of the torsionbars. and they are about 30 Kg/cm calculated towards a springrate for the coil over.
zambon
Post by zambon »
If you weld any panels in the engine compartment be sure to use TIG welding. Arc welding will weaken the thin sheet metal in the area, defeating the purpose of the modification.
I have seen other photos where they didnt weld the whole seam, instead they alternated. A few inches welded, a few unwelded.
I am not sure if this is the correct aproach. I surmised that it was to keep from making the front end too strong and therefore dangerous in a crash.
tectoteam
Post by tectoteam »
exactly.
30 mm welds, and 30mm beetwen each.
2 stroke addict
