hi tmundy i made the tool needed to remove the ring that keeps the bearing in place. I bought a 50mm socket and spare ring then i cut the socket with angle grinder a little bit bigger than the ring splices and carefully filed it for perfect fit.
Then u can torque the ring to 260nm after u are done i cant for some reason get a picture attached
