Mats wrote:Maurizio: Better RC?
up or down?
Up off course, for the gross of lowered transaxles (referring to my V6) But I keep it like it is, is enough time needed to do one semi-racer. And it looks ok so low
For my track car (TS) the rc is ok, but I want to move the CG down
It the common used 105 joint. I didn't like the idea off cutting the already flimsy sheet metal. So I did the spacer design which now is sold in several places. (Performatek sells them in aluminum, rs has derivative in steel).castor bar ball joints
Harshness is not much different from stock setup feel is much better.
ps castor rubber: go to an align shop and get the car aligned. Then lean a moment on the front of the car after that control the alignment. From then on you only want a ball joint in there.
