Mats,
Good suggestion on the welded sleeve lip to prevent the sleeve from sliding through in the event of a failure.
I was thinking about using kevlar and a small steel sleeve to make a seat for the sleeve to butt against. I would epoxy the sleeve to the shock body. Then I would follow by wrapping the steel sleeve with the kevlar cloth and vac bagging.
With regard to the rsr kit, I am sure it is nicer, in a number of ways, than what I am making. If I had the money, I would buy it. (I was ready to buy the RSR kit at one point, but then I used the money to buy another Milano instead).
What type of epoxy should I use under the steel sleeve? I was thinking about using JB weld.
I would use the West system epoxy that i have in my shop for the kevlar part.
I have already collected all of the parts that I need to try this out. So please help me go about it the best way, instead of just suggesting that I bail on the project. I have already spent the money, so I intend to give it a try.
They will machine one groove into each of my shocks. These grooves will hold a snap ring which in turn will hold my coilover adaptor sleeves.
So far I have spent:
$200 for two bilsteins
$80 for two coilover adaptor sleeves
$110 for two springs
$50 for two helper springs
$40 for snap ring groove machining (and shipping)
$480 in total
plus I will need to get a custom upper control arm made. $$$
I am lucky I like to eat beans.
I sent my shocks for the machining. I could have had it done locally, but I think it worth extra time and money to let the manufacturer do it. I should get them back before long.
So I have been thinking about the problems I will run into when I get the shocks back.
First, is it important to bind the helper spring and the coil spring together?
Second, my adaptor sleeves only came with a single nut/spring seat. Many coilovers have two nuts on each shock in order to ensure that they lock into place. Is this just a good idea, or is it vital to my plan?
thanks for all the help
The springs must of course be together some way. I have a plastic adapter in between. They must be available where you got the springs I guess.
My shocks have double "nuts". However, they are pretty stiff to rotate and the shock itself does not rotate like in a MacPearsson strut so there's virtually no force trying to turn it.
I still have not installed them. I need to grind out the shock opening in the upper control arm to make room for the 2.5in ID springs. I will then have some steel welded on to bring the strength back up.
I am also trying to find a cheap way to connect the helper spring to the 600lb coil so that they will stay properly seated at all times. (I'm thinking of using a bicycle tire tube).
Can someone post of a picture of the rear RSR setup. I have on in my shop right now for a customer's car and I need to make sure I have all the parts and understand how it goes on. It doesn't come with instructions, pictures or anything.
I am amazed at how well it's made.
Ok, I got the pictures and the Link, Thanks guys.
- Dennis
Hey Greg,
Have a look at my post on the old forum. There are some pics from and JimK there.
http://www.alfagtv6.com/discus/messages ... 1097842262
'81 GTV6 3.0 QV
'91 75 TS (track)
'02 BMW 330i Touring
'91 75 TS (track)
