Upset what balance, you just said you had terminal understeer?grant wrote:It's quite possible (cause of the understeer that is, I'm pretty sure I have 6 cylinders down under).
So....would it be as simple as mounting the battery in the trunk and ditching the AC or something to get rid of the understeer? The differnece between the two engines is 75-100lbs right? I guess the v6 block is longer..
But regardless, I know people have said otherwise on these 116 cars, but if you do that same move on just about any other car in the world and it will upset the balance of the car..even if cornering speeds increase.
Move all the weight back that you can actually move, throw away everything else. AC? Does it even work on such an old car?
My first guess is that the V6 block is shorter since there is only ~3½ cylinders in line. I'll measure next time I'm i the garage, got some stuff standing around.
No, I have no torsion bars, custom coilover Bilsteins only.Echo Leader wrote:So you have the 30mm bars and the custom Bilstein coils?? Dang....I guess my plan to go with 27mm bars is kid's stuff.Mats wrote:If you cant get a 30mm, go for the 33.![]()
Maybe with my lack of spring rate, a bigger AR-bar would be beneficial?
The Konis obviously have a very different desig spec then the Bilsteins. While the Konis seems to be designed to work with stock springrates the Bilsteins work very well with both the stock stuff (yes, they are a bit over dampened) with the harder springs is where they really shine. Low speed rates are excellent and they have an overflow option if you hit a pothole, they just swallow it.GarthW wrote:
Mats what the difference between yellow Koni's and coil-over Bilsteins?
I mean are they alot better than the Koni's? My Koni's are great, but would like to hear about the Bilsteins!!
The Konis however are super soft in the low speed area, yes they are adjustable but only on rebound which you can adjust from useless to useless, both extremes on the scale, with the distinctiveness and feel of playing the flute with heavy mittens.
This means that the Konis will not work correctly with harder springs but you can make it feel "sporty" if you dial in some rebound, pesonally I only get motion sick by doing that.
Conclusion; if you have Konis and like them you will think that the Bilsteins are harsh the first time you drive if because they actually do what they are designed to do. Over time you will however realize exactly how crappy the Konis are because you will start to notice that as soon as you drive over ~50Km/h the Bilsteins actually do some good on the car and you will gain grip and responsiveness of the car, you can actually feel what the car is doing and more importantly you can predict what will happen in the near future.
