Update:
I have installed the AVO coilovers with 150lb/in springs. This is on a 3.0 V6 75/milano with a slightly lightned front end, (AC and power steering deleted).
The terrible handling I was suffering from before has been improved upon dramaticly. Strangely, ride quality has improved drastically. I drive on Mexican roads that are not pretty. I was expecting to suffer from a bumpy ride after adding spring rate, 150lbs/in isnt enough to make things bumpy at all. I plan to experiment with different spring rates in the future.
I did some grinding on the upper control arms to accomodate these springs, but it wasnt dramatic. These AVOs seem to be a good alternative to the expensive designer suspensions. The shocks I have dont seem to be an off the shelf part, so anyone who wants to go this route needs to know that the RSR and Benninca setups will be easier to impliment.
I did use the brackets that you sent. I finally got them sent to Mexico. Thanks for sending them on.
I am still using the same springs that you used. I wanted to run them before getting anything else. This way I can experience a starting point before I try a different front spring rate.
Thanks again Zamani!
