wheel fitment
Posted: Fri Feb 24, 2006 6:30 pm
by Jose I
Where can I find those lug nuts with the floating seat, to fit 5x100 wheels on a 5x98 bolt pattern, If not I might have to go with the serpant auto wheel spacer with different bolt patern. I realy don't want to do that because space is all ready an issue with these cars.
Posted: Fri Feb 24, 2006 9:32 pm
by Alfa GTV6 NZ
The ones i got mere made by Momo.
So try find someone that stocks Momo products.
Best of luck.
Karl
Posted: Sat Feb 25, 2006 12:27 am
by Micke
OZ Racing had them as well.
Posted: Sat Feb 25, 2006 12:34 am
by Zamani
You can't get these things in the US.
My suggestion is either to permanently change your hub configuration or just modify your wheels. Where I live it only costs me $160 to modify a set of wheels from 5 X 100mm to 5 X 98mm and bore out the center bore from 57.1mm to 58.5mm (basically a VW VR6 wheel to fit the Alfa).
Posted: Sat Feb 25, 2006 1:44 am
by Barry
Jose,MAKE them yourself.....a lathe,mild steel for the conical washer,and high tensile wheel bolts....
