alfanatic
gtv-6 ride hieghts
Post by alfanatic »
i'm planning on replacing ball joints this weekend and installing some new 17" wheels and tires.
while i'm there i want to set ride hieght.
i'm not sure what the car came set at factory or where my car is set in respect to factory settings.
wheels are 17x7.5, 235/40's w/63 rolling dia mounted on car and i measured 26"at 12:00 position on front arches.
would you guy"s that have lowered your cars mind telling me what your set at?
both front and rear
thanks in advance!
Jarle
Post by Jarle »
Hmm, large wheels you have got there. Mine is a 75, but it is the same frame construction and suspension.
Height is 23,2" both front and rear, quite low but fine for track days.
Jarle
Jose_76
Post by Jose_76 »
The standard ride heights for the Gtv6 are:
Front: 19cm (7.48 inches)
Rear: 22cm (8.66 inches)
These measures are taken from the jackpoints under the car to the ground.
