Kerry
leaking hose
Post by Kerry »
the smaller of the 2 hoses on my 87 Milano power steering unit started leaking today, sorry I dont know the technical name for the hose but I sure know it is leaking, checked most stores in my area and the web sight, no luck, any suggestions. Thanks for any help!
Is this the hose that goes from the pump to the steering rack? If yes, that's the high pressure hose. Find a hose shop near you, call them up to see if they have metric fittings and hoses. If they say they do, then dismantle the hose and the banjo bolts, bring it to them so they can make a custom one for you. Otherwise you can check with Centerlinealfa.com, IAP etc to see if they sell the hose. Most hose shops can make the hose for less than $60.
