Smity42
GTV vs 75 DeDion "Triangle"
Post by Smity42 »
Hi Guys,
A nice easy one (hopefully). Is there any differences between the "Triangle" (axle + arms up to the front of the transaxle) between a GTV and a 75? Can I swap a 75 "Triangle" into my GTV?
BTW, what is that bit actually called?
Cheers,
Martin
Re: GTV vs 75 DeDion "Triangle"
Easy indeed.
It is called a DeDion rear axle. And yes, you can swap them between any models. The SZ looks slightly different but then the "risk" of getting one isn't big.
http://en.wikipedia.org/wiki/De_Dion_tube
Weight differences are reported but which ones are lighter or heavier isn't clear to me. I have a stack and don't even remember which car they come from.
The Sei also uses a Dedion axle but with a diff only and the gearbox upfront. That is the only other Alfa Dedion that i can think think off (aside the SZ/RZ one) that is different.
Off course there is a difference in the mounting flanges for the axles and wheels, 4lug/5lug and the bolt-size for the axles. :wink:
Smity42
Post by Smity42 »
Thanks guys.
Giuliettaevo2 wrote:Off course there is a difference in the mounting flanges for the axles and wheels, 4lug/5lug and the bolt-size for the axles. :wink:
Yep, I want to do the swap to get the five stud ;). Seems to be the easiest way after breaking 2 breaker bars trying to get the big 36mm hub nuts off :(. I didn't know about the different bolt sizes for the half shafts though, that could get interesting...
The 75 TS uses the 5 lug but has M8 bolts holding the axle. The 75 1.8Tb and v6 use M10 bolts. :wink:
The thread on the big 36mm nuts is different from eachother, left and right thread on opposite sides. Perhaps you were trying to turn them the wrong way? :oops:
your switching from 4lug to 5lug? what did you do up front? if you're converting a 2.0liter to 5 lug you can get away with only the hubs, discs and calipers but if you have a 1.6liter car you might also have to change the spindles.
Smity42
Post by Smity42 »
Giuliettaevo2 wrote:The 75 TS uses the 5 lug but has M8 bolts holding the axle. The 75 1.8Tb and v6 use M10 bolts. :wink:
Mine were actually both standard Right hand thread nuts (I know, because we EVENTUALLY got them off). They were just seized/rusted on nice and tight.
Based on the workshop manual, I think its the inner nut thing that holds the bearing in that has one side reverse thread (I haven't gotten to them yet).
Fronts I plan to swap the whole spindles over, it is a 2L GTV but that seems like the easiest way.
i believe that the spindles from a 2.0 are the same... if you just swap the hub with the disc and caliper you should be fine.. :)
Smity42
Post by Smity42 »
For those interested, it's all swapped over now.
5 Stud GTV:
4 Stud 75:
Swapped the whole triangle (and the crossmember bit on the front of the deDion) over on the rear. I also made sure to keep the crossmember mounts on the correct car (75 ones seemed to have a an extra bit of spacer metal on the bottom of them)
Neither car has a transaxle or halfshafts at the moment but I'll just use the appropriate halfshafts to match the rear hubs.
On the front, I just swapped the spindles over, brakes and all. This seemed like the easiest option, and I'm sure I read somewhere that the 75 spindles are a bit stronger to support the bigger brakes.
Post by la_strega_nera »
out of curiosity, what are you doing with the 75?
1966 GTV
1982 Suzuki "Bathurst" Katana
Smity42
Post by Smity42 »
la_strega_nera wrote:out of curiosity, what are you doing with the 75?
Stealing parts off it :P
I bought it for the 5 stud, front brakes (although i will use them on the rear and get something bigger for the front) and V6 conversion parts (engine mounts etc). As an added bonus it had a LSD transaxle in the boot, although the final drive ratio is rubbish, I am trying to acquire a 75 box with a better ratio to put the LSD into.
One of my mates wants to restore the 75 when i am done, and use it for a daily. It will no doubt cost him a lot more to replace the parts I steal than I paid for the whole car, but should be fun. We got it running on the weekend :D I love Alfa V6s
