mjr
POWER Steering
Post by mjr »
Hi all.
Im looking from the 75/Milano parts, required to convert my GTV6 to power steering. So I guess Im looking for the rack, pump, brackets etc from a Euro 75. Anyone have the part required available pm me thanks :)
xrad
Re: POWER Steering
Post by xrad »
...and steering column??...
mjr
Re: POWER Steering
Post by mjr »
steering column, can you get away with just parts below the steering knuckle?, or is the fitting to the rack completely different for the GTV6? I seem to recall APE doing a conversion adapter of some sorts to allow the GTV6 steering column to be mated to the 75TS rack. my concern is that with an 83, the rack won't just "bolt" right up. My shop manual shows the 84 GTV6 with power steering, so I presume it may have been an option on the 84, and the 75 rack probably boltrs right in.
