Front wheel bearing modification ideas
Posted: Wed Jun 08, 2016 9:29 pm
by 75evo
Anyone have any ideas? I think the front wheel bearing setup is kind of too old skool. Has anyone adapted a newer bigger sealed type which can take more abuse?
I believe MR2Zig suggest using High Temp 105, but I don't know if that will help too much for track cars.
Wes, the guy who owns the Lemons GTV6 24V adapted a front hub and hweel bearing setup from a Ford Cronw Victoria.
I thinking maybe a rear hub from an Audi TT FWD 180 bhp would work for the front of our cars.
Re: Front wheel bearing modification ideas
Posted: Thu Jun 09, 2016 5:22 am
by Giuliettaevo2
For my giulia i made an adapter that takes a bmw e36 front hub.
The bmw uses a double row ball bearing.
Adapter is made with a press fit for the original bearing surfaces.it is secured by the original nut. The bmw hub slides onto the adapter which has It's owns thread for the bmw nut.
Posted: Thu Jun 09, 2016 5:03 pm
by Duk
What is your intended stud pattern?
JazigK on AlfaBB and Alfaclubvic and I have been looking at using FC (Series 4/5) RX7 Turbo front hubs.
They're aluminium and very light but still use the old school tapered roller bearing arangement with a lip seal rather than much nicer dual angular contact bearing cartrage.
The bearing are larger tho and would definitely require an adapter sleeve for the much larger inner bearing and hopefully a suitable bearing exists for the outer bearing as the Alfa's stub axle is only 1mm smaller in diameter than the RX7's.
The hub mounting face does look to have a different offset to the Alfa's, partly because the RX7 uses the usual brake rotor mounting style, but I haven't looked that far into it yet.
Posted: Thu Jun 09, 2016 10:32 pm
by 75evo
I remember Jazig trying to fab up something with his work's CNC. Didn't finish it I think.
I would like 5x100mm since my wheels are 5x100. So I was toying with the idea of the rear hub of an Audi TT FWD.
I will look into the FC/FD front hub and maybe redrill it to 5x100. Otherwise I have to sell all my 5x100 wheels.
Posted: Thu Jun 09, 2016 11:24 pm
by Duk
75evo wrote:I remember Jazig trying to fab up something with his work's CNC. Didn't finish it I think.
He made his 5x114.3 rear hubs, but the fronts never eventuated, yet. Life and stuff got in the way I'd say.
You certainly wouldn't be redrilling the FC hubs, there's not enough material to drill a completely different PCD set of holes.
FD hubs are different, but I've not seen them in the metal, only ebay pics.
Posted: Fri Jun 10, 2016 2:41 pm
by Giuliettaevo2
This is my solution on my giulia. 5x120 pcd. I have a modified bmw rear suspension on the car, so it's got 5x120 all around.
The E36 rear hubs are the same outer diameter as those from a transaxle. You can press them in the original transaxle wheelbearing.switching to bmw pcd gives a lot of wheel and brake options..
Posted: Sat Jun 11, 2016 6:22 pm
by Duk
105 uprights??? Tell us more.
Posted: Sun Jun 12, 2016 3:20 am
by Giuliettaevo2
They're from my giulia...
Just showed them as an example of what can be done.
https://youtu.be/I4VSLGygPUc
Not a giulia for the purists..
Posted: Sun Jun 19, 2016 2:22 am
by gtv-racer
Nice to see it running Remco.
Cool machine!
