akilljoy
Shock absorber questions
Post by akilljoy »
Hi , my '86 gtv6's old shocks are a little done. I want to get some new ones and there are some used AVOs avalible. They have dampener adjustments and look in resonable shape. They are a good price too. I tried to do a little research and it looks like AVOs dont have a good reputation. I can get bilsteins , but then im into it like 600 bucks after shipping. Can i get some adivice. Thanks. :)
KevinR
Re: Shock absorber questions
Post by KevinR »
My friend had a set of AVOs on his race car and were really good . He tested them on a shock dyno to make sure their adjustments were equal to other shocks . Problem with used shocks you don't know . Try see if you can get them tested and at what cost . I have custom blisteins on my car but most guys here prefer the Konis as they " seem" to be more forgiving on the B roads .
akilljoy
Post by akilljoy »
Thanks man. Its good to hear someone was using them. :)
Post by 75evo »
I was once given a set of free Bilsteins. I soon realized why. Teeth shattering stiff. And they were a very rare inverted style set (for the fronts). That means the body was attached to the frame of the car and the rod was attached to the lower a-arm.
I also had Avos, which were OK.
But Konis for an all-round good set. Koni yellows, not Koni reds.
akilljoy
Post by akilljoy »
Thanks so much for the info!
