My anti AR bar is useless due to worn bushings. I have considered 28 mm bar from RS-racing. Where do I find bushings for chassis joints? Superflex is offering 27mm and 29mm version...
Should I stay with poly bushes in outer joints or go with uniball? Usage is street and occasional track. I am the most worried about chassis mounting points (breaking or not) only then about noise and durability...
If you care about noise and durability you should really use the stock parts, polyurethane (despite what they say in the ads) does not hold up nearly as long as stock rubber, but the poly does transfer sound better...
