Physical location of the badge on hatchback "GTV6 2.5&q
Posted: Mon Mar 21, 2005 5:28 pm
by hutchensgd
My car is nearly completed, and I was wondering if somebody could give me the dimensions from the right edge of the hachback as well as the location from the bottom edge.
Posted: Mon Mar 21, 2005 6:06 pm
by Greg Gordon
I can give you that, I have plenty of hatches here. However I need to know the year of your car and what the badge says, they vary a bit.
Posted: Mon Mar 21, 2005 6:38 pm
by hutchensgd
Greg,
The item I am speaking of is a rectangular badge which has the following text: GTV6 2.5L
Thanks for your help.
Glenn
Posted: Mon Mar 21, 2005 6:40 pm
by hutchensgd
And the car is a 1984.
Posted: Mon Mar 28, 2005 4:49 pm
by hutchensgd
I received my new plate from ItalianCar parts, and it was perfect!
I did notice that my memory was mistaken, it does not have an "L" after the 2.5.
So all I need now is the dimensions to position it. HELP!!!
Posted: Tue Mar 29, 2005 3:36 am
by tectoteam
hello
cant say it to you, the mines as gone years ago....
but ask it on a french forum, numberous owners.
http://www.purassanta.net/forum/posting ... wtopic&f=1
put in the subject: "position du sigle gtv62.5L a l'arriere du hayon"
and the content: 'bonjour, j'aimerais savoir quelles sont les position exactes du sigle 'gtv6 2.5L' a l'arriere du hayon, les dimensions entre le bord droit, haut et bas.
c'est pour le mettre exactement a l'endroit d'origine sur un vehicule concours.'
and i will translate you the answers.
bye
Posted: Tue Mar 29, 2005 3:37 am
by tectoteam
well in fact i did it.
waiting some days for a good answer.
also, there is more than this one.
the gtv62.5L is on the rigth but there is a 'alfaromeo' sign on the left.
Body Exterior
Posted: Tue Mar 29, 2005 4:10 am
hutchensgd
If you get the correct badge, you don't need to obtain location dimensions as the badge is positioned on the rear hatch by two locator pins that go into holes that are made by the factory.
If the holes have been covered over by body filler, use a good torch and look inside the framework of the hatch on the right hand side and you will more than likely see the bit of filler that has come through the steel work. This will be your pin locator hole. Simply drill it out and you will have the exact factory location of where this badge needs to go.
Posted: Tue Mar 29, 2005 10:21 am
by hutchensgd
When I saw my car down to bare metal I saw no holes. In addition, the Alfa Romeo spare part which I purchased for this part had no pins in it either.
Posted: Tue Mar 29, 2005 7:09 pm
by gtv11636
There are no holes in the rear hatch for this badge from factory as much as I know! It came glued on.
Posted: Tue Mar 29, 2005 7:32 pm
by Sporttunergtv6
please pardon my standard measurements but the badge is 11/16 of an inch from the right edge, it is 15/16 from the top edge, and 14/16 from the bottom... hope that helps
vittorio
Posted: Tue Mar 29, 2005 7:33 pm
by Sporttunergtv6
i too have a 1984
Posted: Tue Mar 29, 2005 8:12 pm
by Greg Gordon
I checked my spare hatches and none are 1984s. Sorry I couldn't help.
Posted: Wed Mar 30, 2005 1:24 am
by tectoteam
Sporttunergtv6 wrote:please pardon my standard measurements but the badge is 11/16 of an inch from the right edge, it is 15/16 from the top edge, and 14/16 from the bottom... hope that helps
vittorio
informations sounds the same.
12/16(19mm) form the rigth and 1 inch(25mm) from the top edge.
