More Photos
More Photos
- Installed
- Installed.JPG (37.54 KiB) Viewed 5052 times
- Finished
- Finished.JPG (39.85 KiB) Viewed 5048 times
- L-Jet to DB37 Harness
- Harness.JPG (60.21 KiB) Viewed 5052 times
Backing Plate
Peter,
You need to make the plate longer at the top above the L-Jet box upper mounting hole to get it all to fit. I'll get the dimensions of my board and post then here. Also the backing plate ensures a good earth on everything.
David
David
Hey nice install David. Mine isn't nearly as nice, but I retained the Ljet header still bolter to that metal plate. In order to get the MS box to fit I have it sideways on the metal plate. I had to cut away the fiberglass housing where the old ljet box fit. I think I should be able to keep the serial port cable plugged into the MS box. I'll try to take pictures this weekend.
Bill in MD
Bill in MD
Bill in MD
'88 Alfa Milano Verde x 2
'77 Fiat Spider
'77 Fiat Spider
This is Dave's component set up. i complained that i couldnt see it and he kindly sent me the pdf.. much better.
for you whingers out there:
http://home.swiftdsl.com.au/~joeyamin/FuelPumpModA.pdf
for those without acrobat pdf viewer:
http://home.swiftdsl.com.au/~joeyamin/fuelpumpmod.jpg
