I have a fully built and functional MegaSquirt (parts bought in April of 2004 through a group buy). It is mounted in a Bosch L-Jetronic case which makes it perfect for L-Jet cars such as BMWs and Alfas (among otheres). It also has the flyback board installed in the case for L-Jet low impedance injectors. Because its in an L-Jet case it will bolt into your orginal EFI computer position and will just plug right into the wiring harness. It has also had the necessary fuel pump circuit modification done to it.
My Alfa 75 3.0 V6 ran perfectly with this MegaSquirt and I got it somewhat tuned through the rev range. But I have run out of time to play with the tuning and to be honest I need to the money back for other things. I had it running with MAPdot but it will come with a Vishay TPS (from FarnellOne group buy) so you could run TPSdot.
What your getting:
- Complete and functional MS in L-Jet case with FlyBack board installed and functional
- Air/Water temperature sensor from group buy
- Variable Resistance TPS with mounting plate for Alfa throttle body
- Stewart/Aussie stimulator which is functional and complete
- Serial/null modem cable for PC or PDA connection
I also have other items for sale:
- Handspring Visor PDA with serial and USB cradle, perfect for tuning a MS $55 in as new condition, includes a cable to convert the PDA serial to null modem for MS
- Greddy WIDEBAND air fuel mixture gauge with O2 sensor $250 in fantastic used condition
- 80cm length of 85mm air intake ducting ($35 a metre new) which is heat resistant. Comes with two hose clamps. $25
All prices in AUD.
Items are located in South East Melbourne, Australia.
Will be sending all items via Australia Post if not picked up. Will ship world wide.
Simon
SOLD - Everything has now been sold.
