Page 1 of 2
Success Stories
Posted: Tue Jan 11, 2005 7:26 am
by P.Webb
A sticky reminder:
If you have a running car, or if you get one running PLEASE post yourself to
www.msefi.com under success stories. Lance gave us an Alfa section there.
I'm so tired of hearing about Toyotas and RX7s. Lets outnumber that Japanese crap with fine Italian machinery.
-Peter
Posted: Fri Jan 14, 2005 12:51 pm
by P.Webb
And while we're at it, lets post our success stories here in this thread too. That way new people can see how many cars we actually have running on MS.
I'll go first:
Car: 1987 Alfa Romeo 75/Milano 3.0QV
Specs: 3.0 engine,
stock bottom end,
stock valves,
ported and polished,
head shaved .040,
Shankle AL6216 8L cams,
Shankle headers,
dual exhausts,
custom 3-throttle plenum.
HW: B&G V2.2
SW: MSn-E 020i 12x12 tables fuel only for the time being.
Adding ignition soon.
Car: 1986 Alfa Romeo Spider Veloce 2.0 (sold last year)
Specs: Mostly stock
head shaved .025,
10548 Euro cams.
HW: B&G v2.2
SW: B&G v2.98
-Peter
Posted: Fri Jan 14, 2005 7:04 pm
by David
Car: 1985 GTV6
Full Zender Body kit & Zender Mags
Specs: 3.0 12V engine (from a 164)
stock bottom & top end,
Cams ?? (still trying to find out, maybe S)
Pace extractors,
Enlarged intake runners,
75mm air intake & K&N filter.
HW: B&G V2.2
SW: ?? 8X8 Fuel Table
David
Posted: Sun Jan 16, 2005 8:37 am
by bmacf
Name: Bill MacFarland
Car: 1988 Alfa Romeo 75/Milano 3.0
Specs: 3.0 engine,
balanced stock bottom end,
stock valves,
S-cams,
Shankle headers,
Custom but very leaky exhaust,
Stock plenum and intake...AFM still there.
HW: B&G V2.2
SW: ....uhhh, Used Steve R.'s tables from his installation article, but will upgrade shortly
-Bill
Thanks to everyone on Alfagtv6.org!
Posted: Mon Jan 17, 2005 2:43 am
by Steve R
Steve R
1983 GTV6, 12v 3.0 (ex 75)
Stock internals, except CB 104/294 cams
CSC manifolds, no centre box, Ansa rear.
modified factory airbox, big BMW AFM with no flap (shortly for the spares box as it only provides IAT)
Megasquirt as per my build doc, with ECU running:
MSnS-Extra-enh-020i9.s19 (to give 12x12 fuel tables and option for spark)
Using Megatune version :
MT2.25 b336 021
I've built the base spark tables & configs using the above, have welded up a spare distributor (must re-assemble it!) and have replacement ignitor and coil (scrapyard VW stuff). Will shortly provide distributor based mapped ignition control - once I have some other jobs out of the way.
Alfa GTV6 race motors
Posted: Tue Mar 22, 2005 8:48 am
by Reale
SCCA E-Production GTV6, originally a 1986.
Engines: 1) original GTV6 bottom end, Venolia pistons.
2) Milano 2.5L bottom end, J&E .040" pistons
Heads port matched, 3 angle intake, full radius exhaust.
CSC headers into 2 to 1 merge, out behind the passenger door.
Cams: Richard Jemison specials
Running Megasquirt and Bosch high-impedance injectors (24lb).
No AFM, 3" aluminum intercooler pipe from cone filter to throttle body.
Stock distributor, with MSD 6AL and MSD timing computer.
Flawless race performance from Megasquirt for over a year!
-Al
Posted: Tue Mar 22, 2005 10:13 am
by Michael
(High time I update this!)
1985 Alfa GTV6.
3.0 liter engine and running gear from a 1987 Milano Verde.
Sperry Stage II head prep with 'S' Cams.
CSC headers, Stebro middle and rear silencers.
Megasquirt with MSnS-extra:
http://megasquirt.sourceforge.net/extra/select.html
and Zeitronix WideBand O2 sensor.
No Air Flow Meter, running Greg Gordon intake plumbing with a section of 3" pipe to replace the AFM.
Stock ignition.
Still tuning, so far though, its been awesome - much smoother with more power.
Posted: Tue Apr 12, 2005 10:34 am
by Luis
1986 Gtv6
3.0 liter engine.
Shaved heads (.5mm) ported and polished too, C&B cams, QV pistons.
CSC headers.
1.8 turbo injectors (234cc/min) and raised fuel presure (around 255cc/min)
Megasquirt MSnExtra, wide band o2.
No AFM, and Stock ignition (from 2.5)
Still tuning too.
Posted: Sat Apr 23, 2005 10:21 am
by Peab
Name : Per Abrahamsen
1983 Alfa Romeo GTV6
Stock 2.5L engine from a Milano.
CSC headers, Ansa Rear silencer
Stock ignition
TPS from a scrapyard Opel Omega
AFM with flap fully open. Will change to a free flow intake shortly.
Hardware B&G v2.2
Software Standard code v2.98
Tuning Software: Megatunix running on Suse Linux
With Peter Webb's map loaded in the MS, the engine started on first crank. Engine ran smoothly from then on. (I have turned down ReqFuel due to the difference in engine volume) Will work on fine tuning based on this setup. Future plan is to install C&B "stradale" cams.
Posted: Wed Apr 27, 2005 4:20 am
by P.Webb
1976 Alfetta SCCA E-Production race car
4C 2L 13mm cams, 13:1 pistons etc..
Hardware: B&G 2.2 w/ EDIS mods
Software: MSnS-Extra 024u2
Megatune 2.25b417
Running MSnS-EDIS with the -Extra code. Spark only for right now. Will be putting it on the dyno tomorrow night and running it's first National race on Sunday!
Posted: Mon May 23, 2005 6:54 pm
by Mark Mallett
Car: 1987 Alfa Romeo 75/Milano Gold
Specs: 2.5 engine stock
Stock plenum, intake, AFM (for now)
HW: B&G V2.2 w/flyback board.
SW: MSn-E 020i 12x12 tables (fuel only for now).
Followed Steve R's setup instructions. I used Peters Verde.msq to get up and going. Started on the first twist of the key. Needs tuning but the difference is already amazing!
Posted: Sun May 29, 2005 4:21 am
by aikendrum105
Car: 1985 GTV6
Specs: 2.5 12V engine - stock
ANSA Extractors
MegaSquirt I - MapDotAE code
Followed the instructions generously provided by Steve, learnt the hard way about LJet pins 28 and 29 (why didn't I read the forums all the way through first ??!!) and loaded Steve's sample MSQ file. It runs - but needs a good tinker to get right.
Posted: Wed Mar 22, 2006 2:27 pm
by C.Waltgard
Car: 1984 GTV6
2,5L with 164 3.0 injectors and fuelrail, also plenum from 164 with 3" intake and K&N filter. Ported heads. 164 S cams. Ansa exhaust from extractor to endpipes.
MS II v3.0, fuel only so far. Just started it up, will add ignition later when it runs nice.
Thanks for the L-jet to MS wiring table.
Posted: Thu Jun 08, 2006 7:30 am
by Murray
Car 1986 GTV6 2.5L
Engine mods.:S cams,K&N filter,remove AFM,potentiometer type TPS,Total seal piston rings.
ECU:MSII V3.0 fuel only..for now.
Software:Megatune V2.25
O2 sensor Innovate LC-1 wideband
Well finally I feel comfortable posting this info and hopefully it will be of assistance to others attempting this switch from L-Jet to MSII on a 2.5L engine.
To begin I want to thanks all the great people on this board who helped guide me through this sometimes difficult project.
I used Steve Rossers writeup extensively and it helped a great deal.
I ended up mounting my MS ECU in the stock location on an aluminium plate.MS is in it's own enclosure and is wired to the L-Jet ECU connector which in turn is plugged into the stock L-Jet plug.
For my intake I took the manifold temperature sensor from an old AFM and mounted it in a length of 3" exhaust pipe which I then inserted into the stock AFM to plenum hose.I had to heat the hose in hot water to make it pliable enough to insert the pipe.It turned out pretty well.If you look inside the AR flexible hose you'll see that it is a smooth surface all the way to the plenum so if your hose is in good shape might as well use it.
I used a variable resistor type TPS for a Volvo 850 which required an adapter plate to fit the throttle body.I made this out of aluminium plate and it works perfectly.I have tried both Mapdot and Tpsdot acceleration enrichments (which Megatune V2.25 provides ) and I found Tpsdot much easier to fine tune for my application and skills,so having the appropriate type of TPS is really handy if you want to have the flexibility of choosing this option.
My injectors are Greg Gordon's stage 1 replacements for the stock Bosch units.If you have stock injectors my settings should work for you.
I decided to install a WB O2 sensor so that I could really see what was going on throughout my load and rpm ranges.These things are super sensitive to input voltages and ground paths,so if you use one follow the installation instructions EXACTLY.I found that my electrical system was pretty "noisy" so I ended up installing a 20A stereo noise filter on my power lines for both the LC-1 and the MS ECU.It solved all the problems.
I have run about 3200km.(2000miles) and one track day on my MS so I feel confident posting this .msq file
I would point out that in order to get a smooth idle at 950rpm I have to run very rich mixture approx.12.3:1 to achieve an idle MAP of 40 so don't be surprised if yours is the same.
I recently completed a 1200km (600mile) trip through mountainous terrain and averaged 30 mpg.I have definately gained some power (guess about 5-10 hp.) and will dyno my car this summer.I have pre-MS dyno data so should be interesting.
I've kept the stock Bosch ignition for now but as soon as I have a gap between track events I will switch over to MSII ignition control.I'll update once this is done.
Here is my .msq file and a screen-shot of a datalog (right click and "save as" if you want to see it,for those who would like to see what they should look like.
Posted: Thu Dec 28, 2006 11:23 am
by sprintcarfan
Car: 1991 Alfa Romeo 164S
Specs: All original, no AFM, no TPS at the moment, original Alfa 164 CLT sensor, GM IAT sensor, no idle control (GM IAC stepper setup in the works)
HW: Megasquirt II V3.0, from Glen's Garage; built standard
SW: MSII v2.687, running fuel and ignition with direct coil control; Megatune 2.25.
This engine is currently in a wrecked, but driveable 164S. I will be putting this engine in my Lancia Scorpion eventually, so I decided to 'squirt the engine while it was still in the 164.
I'm running direct coil control (no ignition module, just like the original Motronic system). All 6 injectors are wired to fire at the same time on the Motronic system. Rather than rewire the injectors to fire bank to bank (3 and 3), I decided to run all 6 injectors (16 ohm) from one driver. I am running dual table with the first table running the 6 injectors and the second table setup with 0% fueling across the board. I have no idea if this is electrically kosher, but I haven't had any problems yet. I am going to look into a 3 and 3 bankfire setup when the engine goes into the Scorpion.
Miraculously started on the first try. The V3 board is decoding the stock 60-2 crank wheel (VR sensor) with no problems once running, however it occasionally won't get an RPM signal during cranking. I suspect this is a noise issue because a large portion of the VR sensor wiring is unshielded.
The 164 uses a throttle positon switch instead of a sensor, so until I can adapt a true sensor, I am using 100% Mapdot acceleration enrichment. The Mapdot setup is tricky to tune, so I still have some driveability issues. It's been relatively easy to rough out the fuel, ignition, and enrichment maps. Fine tuning will require some dyno time.
