benski105
o2 sensors and wideband?
Post by benski105 »
i have just bought a MSII for my gtv-6.
i was wondering whether it is recommended to run 2 o2 sensors, one for each bank, or if its not worth the hassle and a single one is sufficient?
if 2 is recommended, can i simply put a switch between the two and select which sensor i use?
i have also been looking into WB o2 sensors and am looking the innovate LC-1. are many people out there running this set up? and is it a worth while investment?
lastly anyone out there running this set up with 2 sensors and some form of switch to select between the two?
any input and suggestions would be much appreciated, MS build is about to commence, i just want to finalise exactly what im running with it before i dive headlong into the build.
cheers
ben
1962 Giulia Ti Race-car
1969 Giulia Super
1987 GTV6- new race project.
Running just one O2 sensor is fine. I wouldn't bother with 2. As for the widebands, I like the NGK unit. It's inexpensive, accurate, and I like the display it comes with.
Murray
Post by Murray »
Ben I've been running the LC-1 with my MS II for over a year now.Once you get it set up precisely according to Innovate's instructions it works very well.I have a single sensor in one of my downpipes (Europipes) and am satisfied with the accuracy.
P.Webb
Re: o2 sensors and wideband?
Post by P.Webb »
benski105 wrote:i have just bought a MSII for my gtv-6.
cheers
ben
Same here. 1 sensor in 1 bank and it's been just fine. Tuned it from scratch with 1 sensor with relative ease. Most of the tuning files around were derived from mine 4 years ago.
-Peter
benski105
Post by benski105 »
thanks for that input!
i have bought a single wideband and controller from DIY autotune!
ill put an extra bung on the other side and swap it over to see if theres a difference.
things are slowly taking shape!
Ms build will start shortly!!
1969 Giulia Super
