bcal
To fly or to resist
Post by bcal »
What works best for the stock low impedance V6 injectors?
Resistors or flyback circuit?
I used resistors on a 2 barrel Holley TBI setup for a 350 chev and it worked well.
Are there any problem with using resistors on the stock alfa setup?
It is a lot simpler IMO.
Brett
Steve R
Post by Steve R »
Hi Brett,
There's no problem with using resistors as opposed to the flyback circuitry. both work fine. Although I thought the newer board builds had the option for heavy duty built in flyback circuitry?
Sorry for not replying earlier, I only just noticed the post.
BTW, haven't touched my MS system physically for 2 or 3 years since finishing it, as it's been totally reliable! I used the flyback board, but only because it becomes a simple software config change if later swapping between low and high resistance injectors.
S
Murray
Post by Murray »
Brett if your using an MSII V3.0 board then the low impedance injector driver circuit is integrated.It works just fine.I've been running mine for over 2 years.Do a search on the MS site regarding the use of resistors ,I vaguely remember reading something about their use messing with injector opening times ?
bcal
Post by bcal »
Thanks guys, I was beginning to think there were no megasquirters on here anymore.
I have an MSII, two in fact, and have been running my 2L with them for years. I keep one as spare and swap them every now and then.
The reason I asked was because I have little room for a flyback circuit due to the design of my case (slide out PCB) and because I have atmos baro sensors on the component side of the board which takes up room.
I did do a sb chev a few years ago with throttle body injection and resistors so I might give them a go this time.
Brett
